I have a 2015 silverado with aftermarket engine and underglow light mods. Well I can usually leave the lights on all night and it will crank fine the next day. Well yesterday I cranked my vehicle and when I go to leave for lunch the truck clicks once, all of my dash lights and instruments come on without hesitation then a click again. Did the same about 3 hours later jumped off the vehicle both times. Well I replaces the battery last night. It cranked fine this morning and ran perfect all day. Well about an hour ago I drove 5 min down the road to the gas station. Cranked perfect when I left my house. I killed the truck for 2 minutes, filled the tank, and behold it does the same thing it was doing yesterday. Had to have someone come jump me off. What could this be?
Sounds like a poor battery/ground connection somewhere.
Could even be internal in the wire and you can't see it.
Did you ever get this issue resolved? If so, I am interested to know what the problem was and how it was cured. I'm having the same issue here... Starts fine most of the time but sometimes just a click and gauges and lights all work but no start. Looking for a spot to begin diagnosing it...
I had the same issue, minus the jump needed, just an intermittent click, no start, ended up being the Starter
Thanks Beer Belly! I'll be looking into the starter for it.
It was the starter. Sometimes it locks for whatever reason and a buddy of mine showed me put the key in the ignition and constantly try to start the vehicle by turning the key on and off. After a few tries it starts right back up
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,367 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
