Hello Everyone
I'm working on a 97 GMC suburban with a 5.7l vortec. it has a P0300 random misfire code that i cannot figure out and is primarily in cylinder #6
what I've done
-Compression is roughly 160
-replaced spark plugs/ wires
-replaced cap and rotor
-replace spider injector with upgraded unit from ac delco
-replaced fuel filter
-pulled distributor to check gear, nothing wrong and check position with scanner afterwards
-pulled valve cover, push rods and valves all move (not measured, but nothing appears broke)
-spraying an brake clean into the intake causes the engine to run smooth and stop misfiring/ misfire goes away at 3000rpms (watching reading on scan tool for misfires)
At this point I'm thinking a hydraulic lifter, or an issue between the spider injector and computer or computer it self
Edited by chance olson
Should you hand spin motor over,and watch hight of rockers?thinking worn cam lobe?or really look close for a cracked valve spring?or was the spider shot for a while?,carbon on intake valve on 6?
