FS: Elite Engineering E2-X Catch Can w/ AN Braided Lines, fittings and OE Quick-Connects
I'm selling my E2-X catch can. I had this mounted in the spare battery location of my Yukon. The AN braided hoses are the correct length for that based on the 6.2L port locations not 5.3L It has AN fittings on the can and the OE gm quick connect fittings so it's literally plug-n-play. All seals/o-rings have been replaced. I'm including the clean-side separator however I don't have any of those hoses.
The can has the third additional port if you need however, it's just capped now. It also comes with the mount for the vehicle... just didn't get a picture of it. Guess I got distracted when I dumped all the oil out of on my garage floor when taking pictures. Sweet! I also updated the ball valve to a full brass as the original started to leak. This valve is more solid anyhow and should hold up better to the heat. As an added leak preventative measure, I screwed in a small hex screw into the drain port. Probably overkill but guess I got paranoid from the old valve leaking. Finally, the can isn't that purple... was just the blazing sun at my back.
Edited by wingsaa
I can vouch for Wingsaa. Met him personally. Great guy to deal with! GLWS!
Thanks Bud!
