Hi I'm new here, tried to help a friend with his 2000 Serria 1500 we replaced the master cylinder and all the brake lines as they were leaking now I can't get the air out of the system, I've done this on my 2007 Serria 2500hd and bleed the system without any problems, trying to figure out what went wrong
What's going wrong?  You keep bleeding, but air is still present in the brake fluid coming out, or the pedal just seems soft?
How are you bleeding (what is the process you are using)?  And in what order are you bleeding the wheels?
Pedal goes to the floor no pressure even with the booster disconnected, bleeding from right rear to left rear to right front to left front, also tried to use a scan tool but wouldn't get connect to abs module, oh I'm using a self bleeding vacuum bleeding tool.
Darn, sometimes things don't work as planned,try to gravity bleed that front brake,crack bleeder,let it drip, tighten, check pedal,I'm thinking you are not getting a good seal on that bleeder with the vacuum tool
did you bench bleed the MC before hooking it up to the truck brake lines?
all the fittings look tight and no sign of a leak?
I'm not a fan of the vacuum bleeders, as they can suck air in via the bleeder screw threads (so it seems like you can't get the air out), but this doesn't seem to be your problem.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
