13 hours ago, flyingfool said:
i found it interesting and have no idea why, but by shifting to neutral  on a 1500 truck , I actually gained more "rear brake bias" durring a stop. I wish i knew more about the brake proportioning system on these truck, 'cause the nose dive brake effect is not ideal. i wish it could be modified somehow
When you hit the brakes the torque converter clutch unlocks and the truck is now pushing the motor adding braking to the back wheels (2wd) or all four (4wd). The speed logic in the TCM will downshift to the gear for the speed on it's own as if you were coasting to a stop. At some point below about 10 mph your so far below the converters minimum coupling speed it no longer matters.
Some states, like the one I live in, there is actually a law against being out of gear while in traffic. Just say' n.
that's what i would think, but coasting to stop, usually the idle speed is about 800-1000 rpm so it still has a push your braking against. i just cant figure why the brake bias changes when in neutral
Edited by flyingfool
That is strange. Mine idles at 535 rpm. My converter stalls at 1635 and starts to couple around 750-800 rpm.
13 hours ago, Grumpy Bear said:
YIKES, I'm only 30K from issues?
That's less than a year away!
As clean as you keep your fluid Marty, I doubt it.  Mine is almost there too.
1 hour ago, flyingfool said:
i would like to find out more info on this, is there a gm tech bulitin  or tech documentation?
not even considering panic stop but just regular daily stop and go action,  neutral shifting makes the truck feel effortless entering the stop and more relaxing, then when in  Drive and having the engine pushing the driveline
Never seen anything about it or how it works save for that explanation given to me once.  Just stumbled across it while exploring the Tech-2.
Sup bud, read most of you comments seem like you have great knowledge with these trucks.
I have a 17 1500, with a 4.3 sadly. My gear ratio is 3.23. With a 6speed transmission.  I’m planning on lifting it to 9” and slapping on some 37s. What gear ratio do you recommend to keep similar rpms to stock. Yes I know 37s with a v6 is stupid but I just love that look.
4.10 and 37's = 31 (stock) and 3.23.
4.30 would be close to a 3.42
4.56 about the same as 3.73
4.88 close to 4.10
If you run in M5 on your current 31's that will give you a feel for rpm in top gear with the 4.10 on 31 or 4.88 on 37.
4.88 close to 4.10
Would this also be same for my truck? 2014 Silverado 5.3 2wd with 3.42 right now already lifted on 37s though but looking to regear soon but I drive on the highway a lot so would 4.10 be the best?
If you wish to keep the 3.42 to stock relationship; then 4.30. There is a small fly in the ointment however. Roll out distance is NOT Pi of the diameter and this reference treats it as if it were. That is a 31" tire will have a rollout of something less but how much? Some places like Tire Rack will have that information for a specific tire.
That said even if off by an inch or so the rpm will be pretty darn close for the ratios I've given.
Use a rpm/gear ratio calculator to see where your RPM's will end up.
I think with 4.10's on those size tires you'd be around 1750-1800rpm at 70mph.
Right now it's probably around 1500 at 70mph if I had to guess.
4.88 close to 4.10
Great info brother. Something I forgot to ask. How will the truck perform with overdrive on those gears.
I’d have to drive it to be sure. But it sounds about right. Just worried about how re gearing will affect overdrive
Ok kinda get it I’ll definitely have to read more on this to make sure I get the right gears for my truck
A tune is required when changing gears and tire size. So whoever does the tune should be able to get it shifting good.
I think the computer/ABS may freak out if you actually put 37's into the tune though, I forget if they can put 35's in the calibration have it be fine and just deal with a slightly off speedo.
Got my truck tuned already, and tires size calibrated already but needa regear and get another tune after I install my exhaust since I’ve done a cold air intake.
Edited by Frankielozano214
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 552 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
