I HAVE 2020 SILVERADO 1500 RST WITH THE BED LIGHTS. MY QUESTION IS HAS ANYONE ADDED MORE BED LED LIGHTS AND CAN YOU TIE INTO THE WIRING FOR THE TWO BED LIGHTS OR WILL IT THROW A CODE
i have a 2019 Silverado 1500 LD - has bed lights , also added a 36" led strip ( front of bed) splice into bed lights. NO Problem
This weekend I had an interesting issue adding two 60" LED light strips down my step assist bars for entry lighting. I tap'd into bed light on passenger side, worked perfect. However when I went to do the same thing on  driver side the LED strip would just flash. I noticed it was only getting around 10v. I ended up tapping into the reverse wire instead and all seems well. Looks great too imo.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
