Hey all,
I bought a set of 2020 trail boss take offs to put on my 2011 Silverado. Didn’t realize the tpms sensors are 433mhz. Apparently stock 2011 tpms use 315. Anyway to get around this, or am I stuck buying new sensors? Like is there a way to “convert my tpms module/control unit to work with the 433 sensors? Selling my old set of wheels and tires so I was going to leave those sensors in.
Truck looks great though!
Thanks in advance!
16 hours ago, DrDaveMD89 said:
Hey all,
Thanks in advance!
Yep, hit up Ebay for new OE sensors that won't cost an arm and a leg.
