House question
MountaineerTom
What does the term "pre-slab" mean, when talking about a house. A realtor told my wife that a certain house we were interested in was a "pre-slab". :devil: Does it have something to do with the foundation?
Are you sure it wasn't "pre-fab". Ther is a place back home where they build houses and then move them to the site. bothe iste built and pre fab have their plusses and minuses.
Not sure, could it have ment a concrete slab, no crawl space, just flat on the ground. My parents house in Florida was built on a concrete slab. Hard to do much else with the water table so high down there.
My sister had a choice of slab or crawl space. Believe it or not the crawl space was a good bit more expensive. I miss the days of a basement. Had one back home in Pa. So nice in the hot summer to go down there and cool off.
Let us know what you find out. :devil:
Thanks for the replies. She thought they said pre-slab.
What would the disadvantages of pre-fab be? I've heard of those. Are pre-fabs generally as sturdy as an on site build house? I just don't want to get something that the walls feel like a trailer. We're going to try and get an appointment sometime this week to look at it, so I'll know more then. I may post a pic in a little while.
I never heard the term "pre-slab."  Pre-fab houses have come and gone a number of times since the '60s if not earlier.  Unlike stick-built homes, the stud walls were assembled at a factory and delivered to the work site and hoisted into place with a crane.  However, I've also heard the term pre-fab used when referring to modern manufactured homes.
:devil: Like Greg said, pre-fab homes are built in a factory and brought to the site and assembled. I have also heard them called modular homes.
BTW, in case you didn't know, the slab is the concrete on which a house without a basement sits on.
Here's what we're looking at. I'll find out more info on it when we get our appointment to look at it. My wife did say the realtor said it was built in the early 80's. 3 bedroom, 3 bath, gas log fireplace, 2 car garage, fenced backyard which runs all the way back to those pines, plus the workshop.
Gotta like the workshop in back. Already wired for cable and phone. Perfect place to park my trailer, store my ATV's, and store all my tools. :devil:
Looks good, I wish I had the lot space for an additional garage or out building
I agree....Looks great!
I have the lot space, just not the $$ to build a decent shop...I am out of tool space right now. :D Especially when you park the ATV's in the garage....I might have to start parking in the driveway :devil:
That is a great looking house man! Good luck! :devil:
Pre-fab housing, at least here in the north east is what most people call modular. The advantages are that the home is built in a factory under ideal conditions and delivered to the site. Much more control over materials and workmanship, and the house is "erected" quickly when delivered.
Disadvantages are the trip to the site can be hard on the frame. Also some contractors that set the homes tend to cut corners. Have had several friends buy modular and get burned when the home was set. Have also seen homes tumble off the trailors when being set.
All in all the modulars can be as good as stick built if you deal with a reputable company.
That house is not a modular by the way it looks...
I'd ask the realtor to define what they meant by "pre-slab". I have never heard that term before, but things are different down South!!!
BTW that is a great looking house and set-up!!! Good Luck!!!
Oh to have all that room. It would give me a place for all my "Stuff" As George Carlin puts it. :devil:
You never can have to much "Stuff"
Looks great!!! :devil:
I would guess she is referring to the "slab" due to it not having a basement...if thats the case. Most homes down south or near the coast dont have basements, they use a slab. It is also used everywhere else were a basement is not needed...this cuts alot of cost while building.
I live in Georgia and alot of homes have basements.
BTW, nice house Tom :devil: .
Shaners, things aren't different down South, they're different up North :devil: j/k.
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
