I’m going to build a rear diff cover guard like the one I made on my ‘08 Silverado. It’s strictly for looks since I don’t plan on actually putting it to the test against any rocks. I traced the cover outline and hole locations while I had the cover off to change the oil. Used some cardboard to make templates for the pieces that I’ll cut from 1/4” steel.
This is interesting. I understand why the need to protect the rest diff. But if you have no intent to wheel your rig why make something like this?
Well, the other obvious reason would be for appearance.  Lots of people put things on their trucks that aren't needed for the conditions they drive in, leveling kits, wheels, fender flares, diff/transmission covers, rollover bars, grilles, lights, probably lots more bits..
That looks professionally made, very nice.
As I stated, it’s strictly for looks, not function. Several years ago I made and sold several of them for Colorados/Canyons. The one I had on my ‘08 Silverado was actually the one I had on my ‘07 Colorado. The hole pattern was the only difference. This will give me something to work on in the garage this winter.
Edited by HoosierZ
  • 5 years later...
Fast forward almost 6 yrs and I finally started cutting out pieces for this forgotten project. Luckily, I found the cardboard templates. It is going to be made of 3/8” thick steel instead of 1/4”.
I like it.
I wonder though - if you backed into something that would warrant the need for this. Instead of smashing the plain cover and maybe damaging replaceable parts inside the diff if it might blow out some of the mounting holes cast in the main housing requiring an axle housing replacement...
Not a criticism, just thinking out loud.
I saw someone who had a grill guard hit a bollard in a parking lot. Ruined the grill guard and bent up the bumper. If the grill guard wasn't there the damage to the bumper would have been similar and might have also included the grill. Probably ended up costing more to buy the grill guard twice, plus the bumper rather than the bumper once and a new grill.
It would take one hell of a hit to damage the housing considering the 3/8” thick steel tying 8 of the bolts together and reinforcing the cover mounting flange. I don’t plan on putting it to the test. Again, the guard is mainly for looks.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
