51 minutes ago, Tulkas said:
So the number the dealer gave me was the short box lifted number.  So on the LTZ with Z71 is it the short box or shortbox lifted?
It would be 75.4
GM's Order guide shows Z71 is NOT available as an option on either Trailboss.   As others posted, the trailboss trucks are the  only ones with the factory lift.
All LTZ are crew cab
GM says - for 4wd crewcab:
short box  75.4"
short box lifted 78.23"
GM's order guide is wrong. Every Trail Boss has Z71. Z71 is not on every Trail Boss. This is my truck. The Z71 badges and Trail Boss decal are how the truck came from the factory.
872d152a19f64e8d5abf30f2d65fdb2e.jpgb8fea5ad5a5228fa2838ae554dc09b0e.jpg11e070434f4d0c98a9e120b5637c2d67.jpg
Trying to figure out what size parking garages I can use.
The best advice I can give you if you're worried about overall height of your truck is don't add more height. Don't get a Trail Boss. Don't get the offroad light that mounts to the top of the sport bar. I have to pay close attention to the garage I go into. The light that mounts on top of the sport bar adds 9.5". The minimum clearance I can get away with for a parking garage is 7'4". If my math is correct that leaves me about 1/16th of an inch for clearance. That's too close for comfort, so the minimum I'll enter is 7'5", and I go very slow. As a result, I can't go into many automated car washes either. In my area they have a 7'2" max height. I've learned to accept it, but if you can't then don't do what I did.
Apologies.
You are correct.
I need to read / interpret more carefully.
What the order guide shows is:
 Z71         Z71 Off-Road Package, includes (Z71) Off-Road suspension, (JHD) Hill Descent Control, (NZZ) skid plates and (K47) heavy-duty air filter
With a bunch of restrictions on availability, and this RPO is not on trailboss
HOWEVER:
Z7X    Suspension Package, Z71 Off-Road equipment with 2" lift. Includes (Z7X) Off-Road suspension with 2" lift and monotube shocks, (JHD) Hill Descent Control, (NZZ) skid plates, (K47) heavy-duty air filter and Z71 hard badge
This RPO is standard on both Trailboss versions, and not available on other trims.
In any case, still means a factory LTZ won't come lifted.
(Not sure why they don't put a Z7X badge on a trailboss)
Edited by redwngr
Apologies.
You are correct.
HOWEVER:
Imo, Z71 has established marketability.
My stock 2020 1500 LTZ Z71 is 6' 6" (78") from level ground to the top of the shark fin antenna. I measured it when I first got it for the same reason you mentioned.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 1 Anonymous, 563 Guests (See full list)
