I've been throwing around the idea of getting some LT headers for my 5.3. I've seen Corsa LT and Y pipe for around $1900 and TSP LT and Y pipe for 1k. A local company called Speed Engineering has LT and Y pipe for $420. I think I need help choosing what brand of LT to go with. Or even if someone else knows of another good company.
Sent from my SM-G955U using Tapatalk
It comes down to how much money you want to spend, and what kind of quality/fitment your expecting. Kooks and ARH are the go to's. But there are numerous other companies that are as good as them and sometimes priced better too. I have kooks on my truck and the fitment is good, as far as quality goes... Well, lets just say for how much they cost I was expecting something more. If there's a next time, I'd like to try ARH or Stainless Works.
I was looking at Corsa because I currently have the Sport catback and I figured fitment would be spot on and if quality is like the catback then I would be good with that also.
I've ran speed engineering headers before, they fit pretty good but it wasn't on this body style truck.
Often times the cheaper headers may have slight fitment issues with the rest of the exhaust but if saving $1000+ is still on the table I would deal with that no problem.
I have the Speed Engineering LT's on my 18 Silverado. I am very pleased with them the fit and finish was perfect. I did replace the manifold gaskets with new oem ones.
Sent from my SM-G988U using Tapatalk
The only real difference I can see with the Speed Engineering headers is that they don't come with cats.  If you need them like I do, they won't work.  Their pricing is awesome though.  I wonder if they have the heavy flanges like Kooks or Stainless works?
I'm going to do some more digging but I'm leaning towards TSP I think that's some good middle ground between brands.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
