2005 1500 5.3L  HVAC blower some times will not turn on.  under passenger side dash there is a plug and if I wiggle it will work.  I think its special plug?  where do i find one? would dealer parts show it and have it?
Part Number
Description
Qty/ Vehicle
15862656
Connector
Resistor, Blo Mot (A/C & Htr)
Resistor, Blo Mot (Heater Only)
CJ3 or C42 hvac systems
Edited by tbarn
DareDog,
Here's a link to a TSB on what your problem probably is and how it is resolved...
https://static.nhtsa.gov/odi/tsbs/2012/SB-10038760-3962.pdf
This TSB will give you a little insight on the history of this issue, however, warranty info will not apply due to age.
Also, you can find these connector/pigtails and resistor modules on eBay. Do an eBay search for 15862656.
Edited by Mr. Z71
Long story made short... no. It would be very difficult to wire direct. The seven pin connector plugs into the resistor module and you would have to connect each wire to the terminals of the resistor module.
ok,   the plug has one bad wire in it. can see where it has gotten hot in the past.    so I am thinking of just taking that one wire and splicing in a wire to from before just before the  one end of the plug to other end.  to avoid the plug then for just that one wire.so just that one wire is not in the plug.   so is that still good idea?
Edited by DareDog
You can try whatever you want, but be aware that you are dealing with a possible fire hazard. Check this video out to see what can happen...
https://www.youtube.com/watch?v=6eeG9zxCo7A
I opted to replace the connector and resistor module per the TSB for this reason on my '03 Sierra. Not saying that you will have a fire if you don't, just wanted you to be aware of what can happen.
Edited by Mr. Z71
  • Thanks 1
is it mainly the plug or resistor problem?  plug here does not have any burn makes on it.    should I still replace it though? thinking of just replacing the resistor with updated one.
What generally happens is resistance builds up at the connector due to weakened contact force at the contact points of the terminals and/or corrosion at these points. As resistance goes up, so does heat. While you’re doing it, I would replace the resistor module and splice in the new connector pigtail for no more than they cost then you know you should have a good connection with minimal resistance.
Now with heat on ,blower on 5. It doesn’t really throw that much heat out now. Its like on setting 2.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
    • I read through that and I won't lie, my eyes rolled at some of the quirks about how it can turn off the trailer braking for example but I can see how it could help control or even up the torque applied to the ground with each wheel in a boat ramp scenario. But of course what it can't do is increase the torque to the wheels if the need is there as it ends up being like driving the four wheel drive version of a two wheel drive ( high range that is ). So far the neighbor that ended up with the 3.0 duramax with the max tow package which meant the 3.73 gears and high range only, I think its been doing ok for what he has been towing but doubt he ventures off into the soft stuff with his holiday trailer. He may have towed his dads river boat locally with it ( he always used his 6.6 duramax before ), I'll have to ask him sometime if he got into a lack of power to the wheels situation as after all that engine produces a lot of torque at low speed once the turbo winds out a bit and I think it has the 10 speed and if so they have a pretty good first gear ratio at 4.70 I see which is vastly better than the 3 or four speed overdrive models of years ago.
