Got a 2001 GMC 1500 Sierra SLE 4x4 pick up. Replaced the actuator. Now, when I put transfer case into 4wd, the 4wd light does not go on, and will not shift into 4 low. Shifter is on the floor. Thanks.  Mark Feuerherdt
you might want to try putting the old actuator back in, to see if the issue is the same.  If so , check that you have a good ground. I am not sure where you are from but I have read the people in colder areas where salt is widely used, experience issues with their grounds giving them service 4 wheel drive codes.
  • txab changed the title to 2001 GMC 1500 Sierra 4x4 transfer case
