This is what I got I don't live in high building area I have had no issues haven't gone on a real rd trip to know if the reception is worse in the mountains but we usually listen to podcasts for those trips any ways
https://www.amazon.com/dp/B01N2WBRAJ/ref=cm_sw_r_cp_apa_fabc_WK-9FbCK0KBHX?_encoding=UTF8&psc=1
Sent from my Pixel 4 XL using Tapatalk
I have the GoRecon stubby antenna and have no issues with AM/FM or HD radio, albeit I am mostly in metro areas too though...
https://gorecon.com/product/aluminum-8-antenna-fits-oem-factory-threaded-antenna-in-black/
EDIT: Only issue I have is the black doesn't last long in the sun. Probably had it just over a year now and the black has faded to a sun worn brownish bronze. May just give it a fresh powder coat and call it a day.
Edited by xSHIFTxNASTYx
The post below may help as it relates to aftermarket antennas. I ordered the 17 inch All Terrain, supposed to be here on Monday and will test out the reception range on it.  The 6 3/4 says it has the 'Best' reception but not sure how that's possible on something so short?  But seems to have several good reviews.
a s
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,481 Guests (See full list)
    • I have 2 choices.
