I've got a 2015 6.2 with ~82k miles on it.  Recently, about 2 weeks ago, I noticed the engine was making a much louder ticking sound than it used it, but I only notice it once the engine is warmed up (haven't heard it on a cold start yet).  The noise does vary with rpm, but there does not seem to be any loss of power or mileage.  Any recommendations of easy things to check or should I just bring it in to the dealer?  We really only drive it on weekends, and I've put maybe 500 miles on it since I first noticed the tick.
Thanks.
Edit: I forgot to mention that the noise is much more noticeable from the passenger side of the engine bay, and that I cannot hear it at all inside the cab when driving, but the ticking is definitely considerably louder than the engine used to be.
Edited by kojimep
Go get a mechanical stethoscope from the auto parts store.  They are like 10 bucks.
put it to the valve cover on the drivers side. If it’s lifter tick you’ll hear it really loud.  If not there put it all over the engine bay.
a long screw drive works to if you put it on the valve cover then put your ear in the screw driver.  But for 10 dollars I would just buy a stethoscope
Thanks.
Vacuum pump?
Getting one today and I'll check it out tonight after work.  Would you hear a lifter tick through the valve cover, or would it have to be on the head directly?  Also on the short list is the vacuum pump like JimCost2014 recommended.
yes to all BUT the vacumm pump it on the lower driverside on the engine bay.  My bad lifter ticked all the time and went up with RPM.
Edited by JONBLARC7
  • 1 year later...
Kojimep did you ever figure out what the issue was?? I am currently having the same issue. I have a 2017 Silverado 4x4 4.3. I took it to a dealer and they said it was normal. However, the ticking is only after warm up. I didnt realize that before taking it in. I have been in contact with Chevy Trucks via messenger and they actually helped me with some other issues that were corrected. I had read somewhere that it could be a purge valve but nothing definitive. Thanks in advance.
I was not able to ever pin point where it was coming from.  Even with a mechanic stethoscope the trick always sounding the same everywhere around the engine.   But the common ones I had checked for were:
*Any injectors louder than the others
*High pressure fuel pump area
*Approx location of each cylinder on the valve cover
*fuel feed hose that goes into the high pressure fuel pump (supposedly a check valve in there that can get noisy?)
*vaccum pump
*exhaust manifolds and pipe going to the back of the truck
I could hear the tick at every one of these locations, and none were ever any louder than another.
That said, a few weeks it started misfiring continuously on cylinder 4 @ 102k miles, found a bent push rod, collapsed and spun lifter, wiped cam, and damaged block.  Had to replace the engine.  I don't know that the two are related at all, but after the lifter had collapsed I didn't seem to hear to that tick anymore.  Definitely hope you don't have my poor luck with this though.
*vaccum pump
WOW, that really sucks. Sorry to hear that result. Thank you for the info. I will check into that list. I am planning on a visit to the dealer as soon as I get my wife's vehicle fixed. I will update after it gets looked at. Thanks again.
source of the problem is your running factory engine t-stat, and probably using 0w-20 oil, i doubt you change oil before 5000 miles. , who knows what engine loading your put the motor under while in such a vulnerbal state.
next time run race oil minimum 10-30wt, get a 170 t-stat, and add and engine oil cooler. this will support the weak components to live longer
Edited by pokismoki
just curious , did the ticking sounds begin after a recent oil change?  only reason i ask is GM has two oil filters that will fit our trucks, one is low pressure bypass, and the other is much higher pressure.  just curious if everyone knows this? and if your running the correct filter?
you have to have the correct bypass pressure to match up with the new variable oil pumps on these gen5's
running the wrong filter can increase wear on the valve train components
Edited by pokismoki
    Fishboat
    Fishboat
  • Who's Online   5 Members, 0 Anonymous, 550 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
