Re: 1997 K2500
Does anyone have a technique or some advice for separating the window lift channel from the window glass? The old channel is rusted to the point that it's binding and causing problems, but it looks like it's basically glued to the bottom inch or so of the window glass. I'm leery of tapping on it and breaking the glass, and thinking maybe I can slip a razor blade between the glass and the channel to cut the adhesive. The glass and channel are sold separately, so it seems the channel is removable.
Any ideas? Thanks in advance.
i would contact a glass replacement shop for insight, is the rollers still in the channel, i have replaced regulators in my 98 , but never glass from channel
  • 8 months later...
I finally got around to doing the job yesterday. Here’s what I found out, in case it helps someone.
The part is “window channel,” Dorman 924-249. It’s roughly 15” long, and has a U-shaped channel on one side (for the window glass) and a C-shaped channel on the other (for the regulator rollers). It’s the same part for the driver and passenger sides. The old part is glued to the window glass with a pretty tough adhesive/sealant.
I used a utility knife to remove as much of the adhesive as I could, including slipping the blade down along the glass into the channel on both sides. I took it slowly, because of course the window is tempered glass -- so one mistake, and it’s “game over.”
I then gently tapped on the channel with a piece of wood, hoping to free it. Then I tried the same with a very wide putty knife. No luck. I finally ended up using an angle grinder along the bottom corner of the channel. I made several light passes, making sure the piece remained cool enough to touch. (I didn’t want to create any hot spots -- that “tempered glass” thing again.)
After five minutes or so, the bottom edge of the channel had been weakened enough that I could peel the side of the channel back with my fingertips and remove the part.
At this point I could see that the window rested in a thin black plastic channel, which in turn rested in the part being replaced.
I left the plastic channel on the window. The new metal channel was a little too tight, so I expanded it until it fit. (I did find that warping the U-channel also warps the C-channel on the other side of the part. It may take some patience and a few tries to get both sides just right.)
I inserted the window/old plastic channel assembly into the new U-channel, using Permatex Ultra Grey as my adhesive/sealant. I let it dry overnight and reinstalled the window. So far, so good.
Edited by ttiwkram
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
