Anybody know if the 2021 overhead console lights are better than the 19-20 models and shine towards the center console? Was thinking of changing mine to the 2021 version if they are better.
Nah, they suck too. Aimed at your lap.
  • Sad 1
I've been contemplating pulling mine apart and physically moving the LED over so it's on top of the hole instead of offset.  The LED itself is almost an inch off to the side and then has a big plastic lens that directs the light at ~45* angle
I'll probably debate doing this for a year or two and then next thing you know, end up in a new truck that hopefully has this fixed already :)
  • Haha 1
The interior lighting on these things is the worst in any vehicle I've had since my 76' blazer.   They are only good if you are reading something in your lap, can't see anything on the floor, glovebox, console, no hood light (I realize that's common these days) etc.
I wonder if you could just remove the lens that is directing the light in a tight spot to the seat area.
I did wire up a center console light under the lid, that helped a lot but really only if you are in the console.   These things absolutely need footwell lighting and lighting in the glove box.   I think I might simply do a rechargeable motion light in the glove box.
2021 Custom here.  I’m attempting to add a cpl LED bolt lights to my ceiling console.  They’re very low power so I WAS going to just tap into an existing light wire. But there aren’t any light wires.  It’s a circuit board.  The LED chip is under the clear “lens”.  I’ll try to post a pic of it. I’m not sure what I’m going to do yet because with this being a circuit board and not just a light socket I do t know what actually controls the lights actions.  A computer down under the dash or that circuit board.  ????  ******.  I guess email me if you want a pic of the front and back of the upper light board.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 2,783 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
