Has anyone tried or know of replacing the 8”  with something bigger? I have a 2018 Sierra 2500HD Denali. I’m just talking about the screen only, retaining everything in the original screen’s capabilities. I see entire radio replacements and with every choice out there, you loose functionality of something. I’ve looked at Alpine, Pioneer, Phoenix, Linkswell, Stinger, MWI, Infotainment, iPad etc and with every one of them, you always loose something. All I want is to replace the screen with something bigger.
If you into the floating type screens, I had the Kenwood DMX1057 10" installed last week.  The shop used Metra Harness/Interface to keep my steering wheel controls etc.  I love it!
IMG_3223.HEIC
Totally unrelated but you may want to toss that hand sanitizer as that was one of the brands that had high levels of benzene e3edb2f1f676d09a029b2e986edcac53.jpg
Appreciate that info[emoji1474]
On 4/23/2021 at 8:14 PM, Tae Williams said:
I ended up doing the same Kenwood except I used an iDatalink Maestro RR2 that kept just about every setting I had. I put in the HDMI cable as well as the USB and had them do the bypass and now we can watch anything while rolling.
Only recently that I had a problem with Parking Assist. It was working better than the original. There were distances on the screen along with the beeps. But last weekend, it went off. Scmar Schmoys (you know who I'm talking about) looked at it and they're going to reinstall the old radio, turn it back on, and but my new radio back in. I'll find out tomorrow.
Took it back and they said that the data cable going to the amp came loose. It’s working now.
Don’t know how it sounds but I like the linkswel look
I've seen a lot of mixed reviews on this HU..
One option I've been waiting on is the Stinger Heigh10. Only problem is availability and price. $1100 for the HU, $430 for the dash kit and all wiring.. and it's not even compatible with Bose so that put's me out. I assume you can do something with the LLJ Customs Bose harness but at almost $2K I'd rather have the Alpine restyle.
https://stingerelectronics.com/products/sr-gm14h
Stinger Electronics now has a Silverado/Sierra specific dash kit for their Heigh10 radio. I have installed the Heigh10, as well as their Elev8 radios in several different vehicles. I am still considering doing this combo as I am looking to replace my older Pioneer AVH-4200NEX, But am also considering sticking with Pioneer, and installing the 9" DMH-WT7600NEX, for one reason. iDatalink Maestro compatibility. I have gotten super used to having it. But if you don't need/want the Maestro Compatibility the Heigh10 is the way to go. The last pic is the Pioneer DMH-WT8600NEX 10" in a Sierra.
Edited by Sinkhole
That system looks great and I have installed a few NEX Pioneers in my old Chrysler convertible and loved them but, on my Chevy, I would hate to lose the MyLink part of the infotainment head unit. I use it quite a bit with the myChevrolet app.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 452 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
