On 2/12/2021 at 1:21 PM, JONBLARC7 said:
Anybody know the part number for the colder CTSV or ZR1 thermostat.
I must be lucky because my stock '16 L86 stat usually runs 175*-180* @ 70 MPH on the highway regardless of ambient temp. It doesn't act like it's stuck either because I get heat pretty quick even the last couple days when it's been bitter cold.
Warm idle it'll creep up but I've only seen over 200* maybe a couple times. And this is confirmed via OBD, not the useless gauge on the dash.
Agree.
According to the Scan Gauge II a gauge reading of 160 F is actually about 105 F, the next mark close to 125 F. The middle point between the gauges 160 and 210 is roughly 150 F. Where the needle is about 175 F and 210 F by the gauge reads 200 to 215 F without moving a needles breadth. With the factory 207 F thermostat it reads straight up. With the Reische Racing 170 F stat about what you see in the photo.
20210211_151458.jpg.78c177158c7f5fce332cf45fcb791bf0.thumb.jpg.b62af16767aa357c323a37dc7ff1dab9.jpg
Agree.
I realize that and I don’t know why they put it that way!
Mine is digital/display, and I got trans fluid temperature 100% accurate, but cooler temp is not!
Is there as much difference between you dash and scan tool as there is between my gauge and scan tool? Curious.
Just record reading at a cold start
This is it:
(Digital Display Gauge — OBD Scan)
160 F — 100~102 F
172.5 F — 116 F
185 F — 138~139 F
197.5 F — 161 F
201 F — Stays there in the middle from 183 F
I use Metric (Celsius) not Imperial (Fahrenheit), so from (84 C until 105 C) it stays in the middle (100 C), it will exceed that when the vehicle reaches 106 C (which is 222.8 F)
  • 2 years later...
I have gone through 4 thermostats in the last 8 months some get stuck open some get stuck closed it’s honestly driving me crazy I can’t figure it out. Im sick and tired of buying them and replacing over and over
I'm pretty sure you've already done a full coolant replacement?
Might be some old coolant fouling the thermostat?
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 423 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
