Hey guys, I have a19 Sierra Limited dblcab with the 5.3. Has about 11k on it. Lately I find that my fuel gauge is very very slow to read the proper level after starting. I know the tank is full or almost but it takes forever to get there. Does it need to be replaced?
I would take it in under warranty and have it fixed correctly, will save you a lot of time and guess work.
Curious if you ever got this issue looked at? Probably a different issue since you said yours does go to full after a while, but a couple months ago for a few fill ups I couldn’t get to full. My last two tanks I found that if I don’t pump the gas with the nozzle open at full flow I can fill it up. With the nozzle all the way open full flow I can only fill up to about 22-23 gallons and the pump/nozzle clicks off and can’t add more. Not sure if it’s an outside temp thing or what.
I’m real leery of overfilling since last year about this time (again it was cold) my evap canister and solenoid were replaced because of a similar issue. I always stop when the nozzle shuts off so I don’t know how I had an issue to begin with. But apparently I did. Temp related issue? Not sure.
I had a similar thing happen today to my 18 Sierra. Filled up truck pump clicked off but I was sure it should of taken more going by reading of gauge before filling. After filling I checked gauge and it showed 3/4 full. I filled 25 cents more gas into tank neck showed fuel so I know it was full now! Gauge still showed 3/4 after ride home and fuel in neck. I will add a bottle of Techron fuel system cleaner to tank. I had a similar situation with a car I store for winter and the Techron cleaned up sensor of carbon and solved problem. If that doesn't work will call dealer. My Sierra only has about 7000 miles it wasn't used a lot this last year so there could have been a carbon build up on sensor. Off to the parts store for Techron !
I know you should fill past pump clicking off , but in this case I wanted to see if was definitely full.
Edited by Borntorun
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
