I'm pushing 170k on somewhat stock 5.3l lmg0 CC gmc sierra 1500. Its the garbage 3.08 gear and g80 locker. Going to regear to 3.73 with truetrac. On 24" 285 40r24. Lowered 2/3 going 3/5. Not important. My question is should I stick with the 5.3l do a afm delete a good choice of torque cam or vvt tsp cam redoing heads, chain oil pump tune etc. Cost would be around 2500 plus labor so around 4-5k on a mildly tired motor. Or do I purchase a brand new l96 6.0l for 5-6k and throw it in maybe throw a mild or tsp vvt cam before its put in. Or do I buy a remanufactured 6.2l l9H do the same for cam as well or not for around the same price of the l96? Problem with the 6.2l is a 2500$ core charge. I do not think my 5.3l would be an acceptable core I would probably have to sell it through the market. Reasons for the l96 is because it's a very reliable motor and it's flex fuel and has VVT and no afm. The l9h 6.2l is the same as well. Its a daily driver vehicle seldom will do WOT pulls. Only do it to pass poeple on highway or to hear the nice engine roar and feel all warm and fuzzy inside. Might pull a fishing boat if the season is right its a 17-18' aluminum hull bass tracker. Didnt really pay attention to the weight. I just feel the truck is a dog just driving around town. Also am worried about the reliability of the 5.3l with high mileage. I know the 6.0l lasts well over 250k miles not sure on the 6.2l. I run Amsoil SS and have universal bypass as well and change oil twice a year. Thays probably not important either. Buying a used engine not knowing what the person did to the engine before me kind of throws my peace of mind out the window. Your suggestions would be appreciated. Thank you.
Personally I would probably do a good AFM delete kit on the 5.3. Swapping the motor means a new ECM and all that jazz which is a much much bigger job. The 5.3 is a pretty reliable engine other than the AFM system.
Keep in mind that most real high power cams also require a torque converter though. I've heard good things about the TSP Stage 2 Truck Cam (+60HP, +30Tq) which is designed to keep your torque converter.
On a related note, you can totally do a cam and AFM delete yourself if you have the interest.
  • 1 month later...
the 6.0 is much more enjoyable to drive with the extra torque vs a 5.3 revver motor. aftermarket is more affordable on the 6.0 vs a 6.2 DI
Edited by pokismoki
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
