Hey all just trying to search for some trans cooler upgrades if any? Lately we have been out on trails and trans temps have been climbing and I want to address it before it gets bad. Temps currently sit around 200 degrees in 4 Hi and on a trail. If im doing more wheeling it can climb higher. The truck is a 2018 with 6.2L sitting on n35s any help will help
Is that with the inline transmission thermostat still in place?
Honestly you'd need to add a fan to any cooler if you are barely moving to help lower temps. Seeing 200 degrees isn't hot either, no need to really worry until you are pushing 230+ consistently.
I would flip the pill in the transline. Those 35s are not helping either unless you re-geared, which in my opinion every person should do going to 35s or larger. As already stated definitely add a fan.
Sent from my SM-G975U1 using Tapatalk
Yes I haven't done anything to the transmission thermostat.
I am regearing soon to 4:10 gears
If I do upgrade to a larger cooler I would want additional fans on the cooler.
