I got a 2017 GMC Sierra 6.2 with a whipple 2.9L. I want to do E85. I installed the sensor in the fuel line. Do I need to do any other fuel upgrades or does it only need the sensor? I know on the 5.3 it requires upgrades, Im not sure if the 6.2 has a better fuel system than 5.3 or is the same.
Some 5.3's come with the sensor already installed 6.2 do not.  I have the sensor install on my 6.2  There is a good thread on here about how to install it by using an exsisting fuel line and heating it up and bending it.  Then buying a sensor and just extending the harness.  That's what I did.
But I say all that to say your probable maxed out on the stock system with just 93.  you'll need and cam with a 32% over fuel lobe, LT4 injectors and some low side support.
On 3/12/2021 at 6:08 PM, DenaliX14 said:
Armageddon fuel pump. It does the trick 😉
Is that an auxiliary pump?
It replaces your intake pump (low side). If you want even more flow you can replace your high side pump to a high flow one.
You can get these from GM parts direct or any equivalent site. Search a 2018 Corvette fuel pump. Select any trim that has a supercharger.
a company called wildhammer.com sells a kit for injectors, pump and fuel line.
goturbo.net has the fuel pump for your tank
Okay so injectors would definitely need to be replaced too?
1 hour ago, DenaliX14 said:
You run out of fuel with stock injectors around 550-600 hp without a supplemental fuel source like meth or E85.
Yeah i have a snows performance meth kit on it. But on the dyno my fuel pressure would drop off at the higher rpms. It helped alot with the AFRs though. They were high like 14 and the meth dropped it down to 12.5. But performance wise the meth did not do much unfortunately. 550-600 at crank or rear wheel? I know my fuel system is maxed. Desired fuel pressure was 2500 and it was at 1700 at peak rpm so it drops off. I wonder if i should put a bigger water meth nozzle in? I have a number 4 nozzle in which is 225 ML/Min. I could put a number 6 in it that i have which is 625ML which is quite a jump. So maybe a 5 nozzle at 375ML/Min
Have you done anything to the block? Rods, journals, bearings, or pistons? I wouldn’t be pushing it much past 550 WHP. My first L86 spun 3 rod bearings at the high 500’s. Diamond or Gwatney performance makes a great drop in kit to bulletproof your block to 1000 crank.
that being said, if you want to push the HP you need to upgrade your low, high side pumps, get a 30% fuel lobe camshaft and drop in the LT4 injectors.
No block has been untouched. I am probably pushing it with where I am at now. Good to know. Ill check them out for future when things break haha. I do need to get Transmission tuning on it. Also trying to figure out of I need the mighty mouse mild or wild catch can.
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
