I suspect I'm going to feel like an idiot in hindsight but anyone know where the Parts Identification Sticker is on a 2021 Denali?  I've looked everywhere and cant find it!  I need to order touch up paint unfortunately and want to make sure I get the correct match.
The Certification label on all GM models is located on the driver-side B pillar, with the exception of the Corvette where it’s on the driver’s door.
Beginning with the 2018 model year, a QR code was added to the Certification label (Fig. 3) on all Buick, Cadillac, Chevrolet and GMC models. The new QR code includes the Vehicle Identification Number (VIN), RPO codes and other information that identify the content of the vehicle. In previous model years, the Service Parts Identification (SPID) label, often located in the trunk or glovebox of a vehicle, included this information.
Edited by elcamino
Thanks for your help; I finally found it!  It was on the pillar but way down at the very bottom.
...and I was right, now that I know where it is, I feel like an idiot for not finding it on my own.
QR code only has the highlights for service information.
If you want the full list any dealer can run your vin and print it or GM social media and get it for you
  • 2 years later...
Still, where is the color code?
3GKALVEV9LXXXXXXX,2020,TXM26,10,19,X ,XBTGNN, AG1 AG6 AR9 AXP AY0 CJ2 CNI DD8 DWL EF7 EPM FE9 FE9 FJW F48 GAZ GNA GND H17 IOS I20 J60 LYX MAH M3U NB5 NTB N43 RJA RUB RV6 SJF SPM TB4 UDD UZ6 U2K V8D WML ZP5 4HM 4SA 4SA 6BM 7BM 8X2 9X2,8624
It depends what your color code is. My truck is Shadow Gray which is code GJI. What color is your truck?
White, but a touchup pint website has two different whites as listed below
Color Code: G1W/GE8/GP5/GP6/WA486BAbalone White Tricoat
Color Code: WA140X/WA472B/WA485BAbalone White Tricoat
So I'm not sure if this reference to the VIN number or something else
GAZ is the code for Summit White
Touchup paint is WA-8624
GAZ / 'Summit White' seems to be one of the colours that is always available. It's the white seen on many many commercial vehicles.
The white tri-coat paints are a different white and won't match.
G1W is white frost -- also has metallic 'frosty' appearance.
You will be unhappy if you use one of the other white touch-up paints on your GAZ white vehicle
Edited by redwngr
