Just Got my 2021 Silverado LT 2wd had it about a week when my wife and i took a trip a few hours away , 2 hours into it i heard a faint high pitch whine (2 seconds ) then radio went blank still heard music playing but had no control even the HVAC started blowing heat until i turned off auto and set manual temp i say it went blank but could tell there was some slight back light ,,, i pulled over shut the vehicle off and exited the truck for a few minutes the music still played and had 0 control over any selection Vol, station etc , i continued on my trip not going to let that ruin our get away figured i keep a jump box with me anyway ,, got to the hotel unloaded truck the about an hour later i went out and it had shut off the next morning was like it never happened and it hasnt happened since but i also havent driven longer than an hour or so since then either i checked for OTA updates says none a few days later i saw theres an update for the radio made an appt at the dealer i worked at for 20+ years as a shop foreman over 35yrs master tech for chevy but now i work for the Govt (still a mechanic tho) theyve told me i have the latest update but ordered a center stack because its a common fault, 1 all i want is for them to update the radio before someone tears my dash apart and replace a part with a guaranteed used referb part that may not be faulty
lt
I saw PI bulletin  PIC6425b that addressed many concerns across the GM line up and saw software v152 as the latest in the bulletin so I checked mine and even tho theyve told me i have the latest i'm at V135 with a date of 10/14/2019 the problem is since i left that dealership many of the techs that knew what they were doing have also left and from what i'm told the most of the techs are from KIA brought over with a new MGR
anyway my next option is to contact some old friends at another chevy dealership and see if i can get them to update the radio BTW the back up camera worked normal when the radio quit
my other concern is the truck has the 8" radio with XM no Nav , my window sticker says 8" radio with XM  but when i scan the QR code for the option label it comes back as the IOR radio which i think is the non XM 7" radio
the truck was purchased new early feb 2021 no mods , i did how ever add a dash cam last week long after the radio concern because i was waiting to get my windows tinted
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
