Hi, I just picked up my first new truck, a 21 2.7l Silverado custom crew cab.  So far I've been impressed by the little motor, it seems pretty efficient and for non towing duties it's just about perfect.
I do have some questions about it though:
  • Is there a catch can for the 2.7l, where do I buy it, and are there online installation directions.
  • What is the proper tire pressure, it was set to 40 from the dealer.
  • I need the 12v outlet in the cab to turn off with the ignition so I can run a dash cam.  Any hacks to get this to work?  I was told it stays on full time which eliminates the use of a dash cam.
  • Any good mesh nets that I can use under the rear seats (crew cab) for storage?  I need something portable so the large plastic trays probably won't work.
  • Does it come with wireless android auto/apple car play?  I have the lower end screen (7"?) if that matters.
  • Can I add a factory brake controller, the truck has the wiring and receiver for towing but it didn't have the brake controller built it.
Loving the truck so far, I'm going to daily drive it for a while to see what kind of mileage I can squeeze out of it.
Nice truck and congrats,...I have really been impressed with our 2.7s in our fleet of trucks.
If they didn't remove it just open the drivers door and read the sticker on the B pillar for the tire pressure. Should be like 35psi for cold tire pressure.
Thanks, I'll do that!  I've read people are getting closer to 24 on the freeway with the latest iteration, with the one trip I took it seems possible.  Didn't have time to drive it today so I detailed the interior, can't wait to get the leather installed.
Look at this video  to learn how to change from always hot to Accessory. Super easy, just move the fuse one over.  Not sure on anything else other than no-go on OEM brake controller. Will need 3rd party.
Just thought of another question, is there a way to tell when the 2.7l goes into 2 cylinder mode?  My vette shows it on the DIC but I haven't noticed any sort of icon on the Silverado.
Congrats on the truck. To answer a few of the other questions, the 7” does not get wireless CarPlay/ AA.
There is no way to add the factory brake controller however GM sells one in the accessory store that I’ve seen people mount in the same slot. Might be the best option.
And 40 PSI is way too high. My truck on 20” wheels calls for 35 PSI.
Thanks, that is really disappointing about the wireless AA.  There is a bluetooth dongle that will do the same thing but it would be nice if it were built in.
I'll look into the gm controller, I don't town often (hence the 2.7) so I can do without for a while.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,978 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
