6 minutes ago, Philbert said:
You should hear the territory MT tires on the AT4 carbonpro. I wonder if I replace just the muffler with a borla attak and keep everything else on the exhaust stock,  will I hear it over the tires?
Same tires on the Trailboss.  So, the tires should "hide" the drone :)
Edited by Rob Mugs
10 hours ago, Rob Mugs said:
Just put some Duratracs on.. you won't hear it over the drone of the tires :)
Man... I hav run the Dura's for YEARS.. on 5 vehicles and well over 700K miles... now that Goodyear went to a (2) ply these tires SUCK!  Drone like crazy... it is entirely a different tire.
On 3/16/2021 at 3:49 PM, Rob Mugs said:
I am only aware of it as my buddy has a Trailboss himself and has a 40 series.  Says he can't hear the exhaust over the tires and I'd be inclined to believe it.  They are not quiet :)
Finally had a Borla atak muffler installed today.  FLAP REMOVED. It definitely is louder and sounds like a v8 and magically the annoying rattle is gone. One of the advantages of removing the flapper.
On 3/16/2021 at 11:34 AM, It's Tim said:
Obviously, really bad info.
If for some reason the engine were to run lean and eat a pistion or 2 that would be on the OPs dime.
How would it cause the vehicle to run lean if the pipe is after the sensors?
On 3/16/2021 at 12:41 PM, Claudio Salgado said:
Would a flow master muffler and resonator delete make engine run leaner?
Mechanically, I can not see how it could cause a vehicle to run lean as there are no sensors after the muffler.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
