Hi all,
I have a new 3500 DRW in transit, I expect it to arrive some time next month. One thing I'm trying to take care of ahead of time is ordering a new drop hitch for the 2.5" receiver so I can jump right into pulling a trailer. But I'm finding it impossible to find the hitch height documented anywhere. I checked with my dealer and they also weren't able to find any documentation on that dimension, and since nobody has any duallys in stock we couldn't just walk up to one and measure it.
If any of you happen to know the height, or if you already have a 20/21 3500 dually I'd really appreciate if you could share the height (measured from ground to the top of the receiver)! Thanks!
Quick rtfm check for where I've already searched:
Edited by John FX
4 minutes ago, Metz54 said:
Just checked a 20 DRW, to the top of the receiver is 22.5".
Thanks! Is that with factory suspension, unloaded? I'm a little surprised since the other post measured a 2020 2500 to be 24". I expected a DRW to sit at least the same, or even higher.
That is unloaded on a 20 High Country, I would think all the trims are the same height. I was surprised as well on one sheet I found from Chevy, the 3500 SRW has a total height 1" taller than the 2500.
4 hours ago, Metz54 said:
Now that I think about it, you get smaller tires on the DRW.
Good call. I just checked a tire website to get the tire sizes from the factory.
2020 Silverado HC 2500 = LT275/65R20 = 275mm * .65 = 178.75mm = 7.08" tire + 20" wheel = ~27" overall
2020 Silverado HC DRW = LT253/80R17 = 253mm * .8 = 202.4mm = 7.96" tire + 17" wheel = ~25" overall
So the DRW's axle is actually 1" lower to the ground. I imagine differences in suspension would raise the rest of the truck up to offset it, so they may be roughly the same overall ride height.
I figure all trucks are a little different so I'll post mine up too. I have a Chevrolet 3500 drw w/t with the Sulastic shackles which raised the rear at the wheel wells 1/4" when I measured. My hitch is 23" from the ground to the top.
Going back to every truck is different though, my last one was a 2018 f350 and one day at a new job site I parked next to another f350. I was about 2" lower in the front and 1" in the rear. He had aftermarket wheels and tires on his so I thought he just had a level kit and bigger tires. You should have heard how upset he got when I asked where he got his level kit, here he had a 6" lift kit on his just to get up to where mine sat from factory.
Sent from my ONEPLUS A6013 using Tapatalk
Thanks for the info! I totally agree, every truck is different. Plus it also depends on what you load into it... if you've got a huge toolbox + a bunch of equipment always hanging around in the back its going to sag a bit.
FWIW in case anyone else discovers this thread and has the same question: It seems like I can expect the receiver height to sit somewhere in the mid-to-low 20"s. I ended up ordering the 10" drop hitch from weigh safe, I figured that will give me the most flexibility even if I don't need to use the full drop all the time.
Edited by John FX
Watch pulling out of parking lots with steep aprons,  I had a 8" drop on my f350 which was about 1" higher than my chevy and it would rub quite often leaving my local dunkin donuts.  It was a 2.5" shank that I bought to replace the shank on my w/d hitch so I just cut about 1" off the bottom and it wouldn't rub anymore.  Just remember the drop hitch isn't measured from top to bottom of hitch it is measured from top to bottom of ball.  My 6" weigh safe hitch with the 2.5 shank is 9" from top of hitch to the lowest point of the hitch, so a 10" would probably be 13" or so which would only leave about 10" ground clearance 4 feet behind your axle which isn't much.
Oh good point, I didn't consider that. In that case I may change out which one I order...
  • 3 months later...
So what did you order and how much clearance from lowest point of drop hitch to the ground?
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
