I'm looking into the Flowmaster Flow FX catback system for around $500 and notice that the muffler itself is only like $50. I understand that this may not give the best results, but for $50, it's tempting to go with just the muffler for $50 vs. the $500 kit. What are the cons of just the muffler? Has anyone done just the muffler? I don't necessarily care about increased power or MPG. What I like about the Flow FX system is the lower overall sound, but still that deep throaty sound. Just enough to know something is different, but not obvious and keeps you wondering what it is.
I did the muffler swap. It sounds great.  I don't understand why people change their whole exhaust on these trucks, just do a muffler swap and save your money for something else.
Thanks, you did just the Flowmaster Flow FX muffler then? Happen to have a part number or link?
Modern exhaust is a stainless steel (but not shiny), mandrel bent, well designed system. Replacing it with most of the modern cat back systems is a waste.
7 minutes ago, Therickyp said:
Thanks. That's the part number I was looking at, but it was showing a round, oval shape muffler. I now see there is a round or normal option.
https://realtruck.com/p/flowmaster-flowfx-mufflers/flm-71249/   "normal" shape
https://realtruck.com/p/flowmaster-flowfx-mufflers/flm-71419/   round, same part # as yours
Did yours ended up being round, bullet shaped like the amazon photo? I wonder if there is any sound difference between round and "normal"?
I installed the FlowFX Cat Back system in my 2021 5.3. It is terribly loud. Might as well just run a straight pipe. The interior sound level is unbearable. Unless, of course, you want your truck to sound like a boat. Flowmaster Series 70 is what I have now. Now it sounds good, and not too loud.  I will starting a thread over the weekend to detail my Flowmaster FlowFX Cat Back experience.
Edited by Diamond817
I installed the FM Flow FX dual kit a month after I bought the truck. To me it isn't overly loud, especially at "Warm" idle. You can hear it going down the road and even better when you put your foot in it. I do believe that is the whole point of installing it---It sounds like a truck now!!
I had my oval Flow FX muffler installed yesterday, 3" inlet/outlet, offset inlet/center outlet, ordered from here:
https://realtruck.com/p/flowmaster-flowfx-mufflers/v/chevy/silverado-1500/2020/
Initial thoughts on the 5 mile drive home are as follows:
It is quite a bit quieter than I expected. It has a stock/slightly higher sound level than stock with a deeper tone. When you get on it, you can tell something is there, but I can't say that someone that didn't know you put the muffler on (ie: wife/neighbor) would notice. I honestly was expecting a little more noise. It's kind of like the gentleman/dad exhaust vs. the 40 series I had on my truck in high school. Pretty much what I was going for. Just my initial thoughts and opinions may vary from others experiences here.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 182 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
