1500 Crew Cab Pricing Out
If anybody's interested GM Released the pricing info on the new 1500 Crew Cab - 2wd, 4x4, Z71...5.3 only. Check edmunds.com or kbb.com
Enjoy.
WOW they are expensive. I priced one out (it for some reason quit working at the end and i didnt get a final price maybe it was to high) but MSRP was almost 40K
Thats outrageous I am disappoint in Chevy all they did was shorten the bed and add 2 reg doors instead of the ext cab doors. So that warrants an increase of 5-10K???? :rolleyes::D
Doesn't look like they will be offering Quadrasteer as an option on the 4WD version. Seems like a mistake to me, as Quadrasteer is one of the major features that distinguishes the Chevy from all the other makes. Maybe the bed is too short to accomodate Quadrasteer??
I don't think the bed is too short, it's just a matter of GM not tooling up the 1500 Crew Cab bed for QS. The 2500 Crew Cab (formerly the 1500HD) and the 1500 ext. cabs that get QS have a 6"5" bed with wide flairs. I guess GM didn't want to pay to tool the plastic (I think it's SRIM) flaired bed in a 5'8" length for the 1500 Crew ....
Scott
Scott
What you say sounds like a reasonable explanation. But for what GM is charging for this new truck, you would think they could invest in the tooling to make the box.
Scott
Not neccessarily true. GM got their asses handed to them on the Pro-tec bed. Plus it's not just the bed you have to consider. The frame structure of this truck probably will not allow for the QS, with the sharp rise directly before the rear axle.
As for the pricing its not that suprising. This will be the first year for this configuration, so expect to pay a premium for it. Next year the price will drop and settle into its correct place in the tier. I look forward to this truck, it certainly has a market with the changing role trucks play now. Ford has certainly done well with their version.
Might as well buy a 2500 Crew Cab or a 2500HD Crew Cab!
Right on Bob you get more truck for a cheaper price. Maybe this is GMs goal sell more 2500s? Plus you get a bigger engine (insert tim allens grunt here)
I'm talking about the bed for Quadrasteer, not the Pro-Tec bed. They are 2 completely different beds -- the Pro-Tec is made completely out of composites and is straight-sided, the QS bed has a steel inner shell with SRIM fenders that are flaired on the side.
As for the frames, the 1500 Crew Cab ("shorty" bed) uses the exact same frame as the 1500 ext cab (short bed), and you can get QS on that truck.
Scott
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
