My application is overlanding and maybe some medium speed over bumps. I don't really like lift kits because I'm not interested in cutting the frame and I feel like it will be easier to liquidate a long travel kit should I sell the truck. I also like that LT kits actually give you more center clearance since it doesn't drop the LCA mounting points.
The biggest thing I'm apprehensive about with LT kits is I don't see any with sway bar attachments. I tow a 7500lb camper cross country with my truck and without a sway bar I'm worried about how well it would tow. Anyone on here have the baja or dirt king kit? How bad is the truck on road without a sway bar? Thanks in advance for input.
Running a sway bar on a long travel kit can be tricky. Causes all sorts of clearance issues.
I'd probably re-think a long travel kit for your usage. I think a mid-travel kit would probably work out better for you. King/fox/icon coil overs with a new UCA and maybe even a stock length LCA would be a massive improvement over stock.
I didn't realize there were mid travel kits. Does that refer to just a UCA swap and coilovers or do they come with LCAs with sway bar linkage?
Mid- travel is usually UCA and coil overs.
However Baja Kits makes a stock length LCA with an option for a swaybar connection.
https://www.bajakits.com/i-31570261-19-silverado-sierra-1500-2wd-4wd-stock-width-lower-arm.html?ref=category:1459192
Interesting. I wonder what the point is if they're the same length as stock? Stronger surely but no lift or additional travel. I guess I'll just have to go with UCA, coilovers, and a 1 inch front lift. It's just a shame I'll be murdering my half shafts with that setup. I guess I was kinda hoping somebody would tell me coilovers and LT would be stuff enough not to need a sway bar on the road 🤣🤣. I appreciate all the input.
I tow a 3400# enclosed sled trailer with up to 3 sleds and gear so closer to 7000#, on 37's with no swaybar on a Bajakits 4wd long travel kit. I have deavers in the rear but airbags on daystar pads. Runs great. Little under geared but the 6.2 tugs it all pretty good and trans temps stay right around 150-170.
There is some spindle modification required (grinding) to clear the LCA on this kit. I bought the swaybar links thinking I'd install them to tow in the winter but have not even considered putting them on. I would recommend going with the dirt king kit over the Baja Kits for fit, finish, and features.
Edited by hushpuff
Additional info
Thanks so much for the input! So the truck doesn't sway too much under normal turns?
Now I've just gotta find a rim that can compensate a little for the 3 extra inches of control arm. They don't make fenders for the GMC to my knowledge so if I can have the track in the front only about 4 inches wider that would be perrrrfect!
I went with 0+ offset wheels and the KO2's are technically 36" but when I had stock fenders the tires definitely smashed them on full compression. The fiberwerx fenders clear great but don't do much for mud and road spray. I wish someone would come out with 6.5' bedsides. Tires still hit the factory fender liners as I re-used them and added HDPHE extensions to seal up the gap on the wider fender.
Truck sways more than stock for sure but it's never uncomfortable or unnerving. No sway bar upfront might just be my favorite mod after the kings.
Hmm, at the biggest I'd probably go with 34s on mine, do you reckon they would still rub at full compression on stock fenders? No worries if youre not sure, probably gonna call the manufacturer today.
Edited by Juggsauce
5 hours ago, hushpuff said:
Bajakits claims that 35's will fit without contacting so you should be fine at 34. Send an email over to [email protected], he'll be able to fill you in on tire size and wheel spacing, etc.
One more question! Did he tell you there's a sale ending tomorrow? Planning on doing business with them in a few months but wanted to know if he says that to everyone 🤣
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
