Ok got a question in regards to the infotainment system  in a 2021 3500 HD Denali !
 I have my own personal WIFI with unlimited data , and I would like to connect to it , but every time I start my truck it connects to the onboard WIFI , that was set up the day that I purchased it ,  every time I disconnect  from my truck my Android Auto shuts Down.
Is there a way that I can connect my phone to my own personal WIFI , and Still have the Android Auto work Wirelessly ?
I do not have my truck yet, but try this.  Go into the settings on the truck and turn the hotspot off, or delete the trucks network (ssid) from your phone.  Now your phone shouldn't be able to connect to the truck via wifi.  I think android auto just uses bluetooth so make sure you phone is paired to the truck via bluetooth and your hotspot via wifi.  That should let you pull data from your hotspot and still use android auto on the truck.
Did that , and Soon as I disconnected the wifi , I lost all Infotainment features through Android .
But Will try the hotspot tomorrow , but I think I did that a few weeks ago.
I may have to go to GM and See what they can do.
The hotspot is how Android Auto works, you can do music streaming over bluetooth, but not Android Auto.  It technically wont make any difference, except you cant use your wifi hotspot, and some Android applications arent updated to properly switch to cellular data when the wifi connection doesnt have internet on it.  I am in the same boat as you, it just is what it is.  If you do find a way around it, I am definitely eager to hear, but I havent been able to trick it in anyway.
Well I'm going to the dealership here later today , and or tomorrow , there has to be a way to get around it !  " or is it just a way for on-star to try and get you to buy there data Package ? "   Hmmmmmmm !!!!!
I will keep you informed !
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
    • Or put you in a lawn chair on the curb, with a free sign.
    • Still $4.50 85 oct.
