I get stabilitrak message every time I turn on truck with code U0126 on OBD reader. I checked voltage and seems fine. I replaced the SAS module and tried to recalibrate but still got the light on dash. I also went through electrical manual and checked most ground points and they seem fine plus voltage seems good on actual SAS module connector. Any ideas? Could it be ABS module since my OBD scanner had the code under EBCM?
 I’d be a little suspect of other issues contributing to the stabilitrac message & codes. I posted my results on a nearby thread about a ‘electronic brake control module’. There has been recalls on various models over recent years.
  The ‘wheel spin sensors’ at times are mentioned. The issue with my EBCM was traced to a weak vacuum pump, another frequent problem that could eventually give stabilitrac codes. My main braking problem was low speed, low engine rpm.
  In my experience, a ‘stabilitrac’ message or code is just an indication of erroneous input, not the stabilitrac itself.
    Markey
    Markey
  • Who's Online   3 Members, 0 Anonymous, 1,564 Guests (See full list)
