I get stabilitrak message every time I turn on truck with code U0126 on OBD reader. I checked voltage and seems fine. I replaced the SAS module and tried to recalibrate but still got the light on dash. I also went through electrical manual and checked most ground points and they seem fine plus voltage seems good on actual SAS module connector. Any ideas? Could it be ABS module since my OBD scanner had the code under EBCM?
 I’d be a little suspect of other issues contributing to the stabilitrac message & codes. I posted my results on a nearby thread about a ‘electronic brake control module’. There has been recalls on various models over recent years.
  The ‘wheel spin sensors’ at times are mentioned. The issue with my EBCM was traced to a weak vacuum pump, another frequent problem that could eventually give stabilitrac codes. My main braking problem was low speed, low engine rpm.
  In my experience, a ‘stabilitrac’ message or code is just an indication of erroneous input, not the stabilitrac itself.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
