Ok..  so I was uninstalling my rollbar on my 2019 custom trailboss because I had plan on trading it in this weekend to a LT trailboss. Got to the wire harness part and could not get the wire out from underneath the fuse box under the hood. So I ended up just cutting that wire. (It was the correct wire, wire for the roll bar harness).  Went to start my truck and now it won’t start, won’t even crank. Music, lights and everything comes on but it will not crank.
it says to service battery charging system, service esc, service 4 wheel drive, traction control off.
hooked my scan reader up to it and it’s showing 8 codes.
P062B. P0690. P16B3. P16BF. P062B pd. P0690 pd. P16B3 pd. P16BF pd.
I got a appointment Wednesday to get it towed and looked at by the dealer but does anybody know what the problem is?  I checked fuses and relays and none seem to be blown, unhooked the battery for about 20 mins and nothing, any ideas??
Did you check to make sure the negative cable for the starter was still connected to the negative terminal of the battery? It may have dropper under or next to the battery between the battery and firewall under the windshield if you messed with that terminal. It happened to me once, and I didn't realize it. Check to make sure it's still connected.
1 hour ago, dctackett10 said:
5.3
I'm somewhat concerned here.  I think whoever installed the sport bar originally tied the bar into the wrong circuit and now you cutting the wire has interrupted the Powertrain Main Relay #1 power supply hence your no start.
You are gonna have to pull the UEC off and get down to the connectors.  The connector they should have tied into is X2 (top right) but it sounds like they tied into X3 (bottom left).
X50A Fuse Block - Underhood X3 (L82)
Connector Part Information
  • Harness Type: Engine
  • OEM Connector: 33384584
  • Service Connector: 19371176
  • Description: 44-Way F 1.5, 2.8, 6.3 CTS, 9.5 MCON-LL Series (GY)
Terminal Part Information
Terminal Type ID
Terminated Lead
Diagnostic Test Probe
Terminal Removal Tool
Service Terminal
Tray Name
Core Crimp
Insulation Crimp
I
13582286
J-35616-35 (VT)
J-38125-557
1241390-1
Lear 17
F
D
II
19332365
J-35616-14 (GN)
J-38125-560A
Not Available
Not Available
Not Available
Not Available
III
19332366
J-35616-35 (VT)
J-38125-212
Not Available
Not Available
Not Available
Not Available
IV
Not Required
J-35616-22 (RD)
No Tool Required
Not Available
Not Available
Not Available
Not Available
Pin
Size
Color
Circuit
Function
Terminal Type ID
Option
A1
0.5
VT/GN
439
Run/Crank Ignition 1 Voltage 4
III
A2
0.5
0.5
WH/GY
VT/BK
2139
2139
Run/Crank Ignition 1 Voltage 21
III
A3
Not Occupied
A4
0.5
BN/GN
59
A/C Compressor Clutch Control
III
A5 - A6
Not Occupied
B1
2.5
YE
6
Starter Solenoid Actuator Crank Ignition Voltage
I
B2
0.5
YE/BK
625
Starter Enable Relay Control
III
B3 - B5
Not Occupied
B6
2.5
RD/GY
1342
Primary Fused Battery Positive Voltage 13
I
C1 - C2
Not Occupied
C3
BK
4450
Ground 44
II
C4
0.5
WH/GY
459
A/C Compressor Clutch Relay Control
II
C5
0.5
VT/YE
3854
Cabin Heater Coolant Pump Motor Control
II
C6
0.5
VT/BU
5290
Powertrain Main Relay Fused Supply 1
II
C7
0.5
VT/BU
5290
II
C8 - D1
Not Occupied
D2
10
RD/WH
342
Primary Fused Battery Positive Voltage 3
IV
E1
Not Occupied
E2
10
RD/GY
642
Primary Fused Battery Positive Voltage 6
IV
F1
Not Occupied
F2
0.5
YE/VT
4325
Starter Pinion Solenoid Actuator Relay Control
II
F3
0.5
RD/BN
440
Secondary Fused Battery Positive Voltage 4
II
F4
0.5
YE
5991
Powertrain Relay Coil Control
II
F5 - F6
Not Occupied
F7
0.5
VT/BU
5705
Powertrain Main Relay Fused Supply 6
II
F8 - G1
Not Occupied
G2
0.75
VT/BU
5292
Powertrain Main Relay Fused Supply 3
III
G3
Not Occupied
G4
0.5
VT/BU
5293
Powertrain Main Relay Fused Supply 4
III
G5
VT/BU
5291
Powertrain Main Relay Fused Supply 2
III
G6
0.75
VT/BU
5291
III
H1
2
VT/BU
5290
I
H2
VT/BU
5292
III
H3
0.5
VT/BU
5294
Powertrain Main Relay Fused Supply 5
III
H4 - H5
Not Occupied
H6
0.5
VT/BU
5290
III
Edited by newdude
Quote
UEC (Underhood Electrical Center)
  1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection in Vehicle Service Manual.
  2. Disengage the retaining tabs and remove the UEC cover (1) from the top of the UEC.
  3. Remove the nut (3) and terminal ring (4) from the UEC terminal post (1).
  4. Loosen the four bolts (2) on the top of UEC.
  5. Disengage the retaining tabs (1), pull up and remove the UEC (2) from its base.
  6. Remove the fasteners (4) from the UEC base (5).
  7. Disengage retaining tab (3) from side bracket (2).
  8. Lift up and remove UEC base from brackets (1), (2).
  9. Locate body 2 connector (2) in the UEC and remove body 2 connector (2) from clip to access the wire side of connector. Refer to Delphi Connectors in Vehicle Service Manual.
    Note: If terminal is not present in cavity H1, insert the CHMSL wire terminal on the sport bar harness into cavity H1 and proceed to step 13.
  10. Locate Cavity H1 (1) on the Body 2 connector (2) in the UEC and remove the terminal from Cavity H1, if present, DO NOT CUT OFF terminal. Remove Terminal per service guidelines. Refer to Delphi Connectors in Vehicle Service Manual.
  11. Use slit in convolute to insert terminated CHMSL wire from underbody harness into Cavity H1 in place of the removed circuit.
  12. Cover the terminal that was removed and the un-needed terminal from the accessory harness with vinyl tape and store them out of the way. Proceed to step 14
    Note: Do not cut off the terminal that was removed, the vehicle owner may want to return to the original CHMSL.
  1.
So after you've digested the info above...
HOPEFULLY who ever installed it left the terminal for that in there taped up on the end of a piece of wire.
If not, you will have to splice the end of the sport bar wire with the terminal that you left in there into the wire that should be taped up near by.  It sounds like it was tied into slot H1 on X3 so in the picture of the electrical main connectors, the bottom left.  It SHOULD have been put into H1 in the top right plug which is X2 connector.
The slot H1 ignition relay supply #1 power wire per the connector chart above is a VIOLET WIRE with a BLUE STRIPE.
Edited by newdude
DTC P0690
Engine Controls Ignition Relay Feedback Circuit High Voltage
DTC P1682
Ignition 1 Switch Circuit 2
DTC P16A7
Engine Controls Ignition Relay Feedback Circuit 2
DTC P16AF
Engine Controls Ignition Relay Feedback Circuit 2 Low Voltage
DTC P16B3
Engine Controls Ignition Relay Feedback Circuit 2 High Voltage
DTC P16BC
Engine Controls Ignition Relay Feedback Circuit 3
DTC P16BD
Engine Controls Ignition Relay Feedback Circuit 3 Low Voltage
DTC P16BF
Engine Controls Ignition Relay Feedback Circuit 3 High Voltage
  • 3 years later...
I know it's a long shot but did you ever figure out the issue from 3 years ago? I have the same thing going on.
Edited by jernizzle
  • 2 months later...
How about you? I have the same issue.
Terminal Type ID
Terminated Lead
Service Terminal
Tray Name
Core Crimp
Insulation Crimp
I
13582286
J-35616-35 (VT)
J-38125-557
1241390-1
Lear 17
F
D
II
19332365
J-35616-14 (GN)
J-38125-560A
Not Available
Not Available
Not Available
Not Available
III
19332366
J-35616-35 (VT)
J-38125-212
Not Available
Not Available
Not Available
Not Available
IV
Not Required
J-35616-22 (RD)
No Tool Required
Not Available
Not Available
Not Available
Not Available
Pin
Size
Color
Circuit
Function
Terminal Type ID
Option
A1
0.5
VT/GN
439
III
A2
0.5
0.5
WH/GY
VT/BK
2139
2139
III
A3
Not Occupied
A4
0.5
BN/GN
59
III
A5 - A6
Not Occupied
B1
2.5
YE
6
I
B2
0.5
YE/BK
625
III
B3 - B5
Not Occupied
B6
2.5
RD/GY
1342
I
C1 - C2
Not Occupied
C3
BK
4450
Ground 44
II
C4
0.5
WH/GY
459
II
C5
0.5
VT/YE
3854
II
C6
0.5
VT/BU
5290
II
C7
0.5
VT/BU
5290
II
C8 - D1
Not Occupied
D2
10
RD/WH
342
IV
E1
Not Occupied
E2
10
RD/GY
642
IV
F1
Not Occupied
F2
0.5
YE/VT
4325
II
F3
0.5
RD/BN
440
II
F4
0.5
YE
5991
II
F5 - F6
Not Occupied
F7
0.5
VT/BU
5705
II
F8 - G1
Not Occupied
G2
0.75
VT/BU
5292
III
G3
Not Occupied
G4
0.5
VT/BU
5293
III
G5
VT/BU
5291
III
G6
0.75
VT/BU
5291
III
H1
2
VT/BU
5290
I
H2
VT/BU
5292
III
H3
0.5
VT/BU
5294
III
H4 - H5
Not Occupied
H6
0.5
VT/BU
5290
III
That link takes me to a GM site asking for a login
We are here to learn more about your concerns and act as an extra layer of assistance. So that we can help, please send an email to [email protected] with "GM Trucks Forum" in the subject line. We look forward to your message. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
Don't click it.  That's why the chart is posted.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
