I have a 2003 Sierra 1500 SLE. I noticed the other day that when I lock my driver's door with the door controls, it cycles to lock and then kicks back to unlock position. If I used the remote it locks and stays locked??? Can anyone tell me why this would do this and what I can do to fix it? Thanks in advance!
I don't totally have an answer for you but if the truck thinks the key is still in the ignition, that's what it's designed to do. Do you have the ability to look at the signal coming from the ignition on that?
Does the truck ding with the key out and the door open? It will ding if it thinks you're leaving with the key still in the ignition
None of my chimes work. Idk if it's due to the aftermarket radio or what but it hasn't dinged the entire time I've owned it
