As we all know our trucks only hold 24 gallons of fuel and that can lead some range anxiety, especially when venturing into unknown territory. As a safeguard I bought a 3.5gal Risk Racing fuel can and mounted it in the rear bedside pocket with a strap. It fits perfectly and doesn't interfere with loading other items in the bed.
I have something similar planned.  I'm going with the Valhalla Offroad MOLLE side panels and mounting Rotopack fuel cans in that area.  Definitely agree with fuel range concerns when offroad, but what vehicle owner isn't?
You will only be able to fit 1 gallon cans on the panels
Good engineering is finding the right hammer to pound a square peg into a round hole.  Hold my beer.  After all, I got a Retrax bed cover to fit with the GM Accessories sport bar installed.  Neither are mounted in a way that differs from their installation instructions.
Edited by Transient
Already tried and failed with a 2 gal rotopax.  You will have to use 1.75 gal or smaller rotopax because the 2 gal wont fit with the MAPS panels unless you use multiple mount extensions and it sticks out into the bed waaaay to far.  Rotopax also has the cylindrical tubing canisters that would fit but they are stupid a$$ expensive.
Edited by Gangly
20 hours ago, Gangly said:
Already tried and failed with a 2 gal rotopax.  You will have to use 1.5 gal or smaller rotopax because[b]the 2 gal wont fit with the MAPS panels unless you use multiple mount extensions [/b]and it sticks out into the bed waaaay to far.  Rotopax also has the cylindrical tubing canisters that would fit but they are stupid a$$ expensive.
The bolded part smells like hope, and I haven't even tried yet.  Thanks for the insight.
Would love to do a rack and RTT but for how often I’d use it probably isn’t the choice for me as I need to take it off and store (at least the tent) for daily use.  May have to DIY something REAL fancy! Lol  love seein what y’all are doing though !
Hey Guys! I was excited to see this thread. I had a camper I pulled behind my offroad rig and decided to downsize a bit. This is what I have so far. I pull the tent off so I can mount my Kayaks on top. In the future they will be mounted inside the rack with the tent on top while being able to see out the middle back window.
Edited by dudleyfj40
I have three optimas in the rear with an inverter. I bought a hog crate to put in the kennel for our new pup. When I removed it from the kennel, I noticed the slots looked really close to the Molle's. So I cut it up and installed it around the drivers side wheel hump. Works pretty good and saved me about 500 bucks. LOL
I'm looking for a video or something on how to mount a rack to the roof ditches under that plastic strip for some solar panels. If anyone has done this or saw how to, please share.
Looks Great!  Its nice to see others modding their T1's since their is such a small market for it in off road recreation right now.  Hopefully that changes soon though since the rest of that market segment is booming.  Unfortunately, I haven't seen or built anything regarding mounted solar panels on the bed rails, but I do find myself searching Tacoma forums for solutions to many things :)
What's running through the rubber hose that is mounted upwards, and to the right, of the interior bed light?
It's an power cord for my LED bar and then later an AC unit for the window of my RTT. That extruded aluminum is nice to work with and very sturdy when mounted correctly. I added tape to the led as a type of diffuser.
5 hours ago, Transient said:
Not enough dirt.  I can still see the truck in the picture.
That’s the first day, I think the second day might have enough dirt but haven’t looked at those photos yet haha
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,331 Guests (See full list)
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
