The search function doesn't turn up much for re-gearing a T1... Are there options yet for us? It like to bump up from the 3.23 my 3.0 has before I get bigger tires.
From what I understand, the front is welded, and thus the whole assembly needs to be swapped, had anyone done this? Where the cheapest place I can get the parts? What about lockers, am I SOL for the front end?
The front end probably doesn't have a locker available for it.  Wouldn't be very street friendly either.
The 9.5" 12 bolt rear is a variant of the old GM 9.5" 14 bolt Semi Floater so it can be regeared with earlier generation parts and use their lockers.  This has been done before.
Copy that. I guess to clarify; I'm trying to figure out if there are any vendors selling re gear Kits for the front end. So far it looks like I'll need to buy a whole new front diff assembly to do a re gear.
The more gears the transmission has the less the rear end gears matter. Those 10 speeds don't really need gears if you stepping up to 33's or larger. Plenty of guys are running 35's no problem.
How will you tune it for the gears?
It's not like the old days where we had 4 speed auto's and putting 35's on a 3.42 gear truck turned it into a 3.08 geared truck that couldn't even get out of it's own way.
I’d bet you could swap axles with a 3.42 geared truck to get a bit lower.
Ditto on the new transmissions. Ever since the 6 speed they’re super low geared and pull hard, even with higher axle ratios than traditionally.
At any rate the front diff can for sure be taken apart and serviced. So at the very least right now there will be GM axle sets available. 3.23, 3.42, and…3.73?  What’s the gear ratio on the 3.0L with the towing package?
Mine has the 3.23 in it. I mainly want to get back some of the lost mpgs from the tire upsize. When I regeared my tundra for 35s I went from 13 to 16 mpg. Some folks don't care about mpg but I bought this thing in September and have 30k on it already so it kinda adds up fo me.
If I were you I wouldn't regear, think of it this way the money you put out for a regear lets say $2000.00 and you pick up 2mpg it will take you years to recoop that money put out for gears to pick up 2-3 mpg. How did you get your mpg with the bigger tires? If you used the odometer and you have bigger tires your mpg calculation will be off because your recording less miles driven cause our speedometer is off.
    tblt44
    tblt44
  • Who's Online   5 Members, 0 Anonymous, 759 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
