Bloody Marty Posted May 23, 2021 Posted May 23, 2021 These are the original wheels from a 2019 Trail Boss Custom. I know they are 18" but does anyone know the width, backspacing or offset? Anyone know? I'd like to get some bigger tires (35's) after having a leveling kit installed but want to stay with these wheels, I like them. I want just a "little bit" of poke but not too much. Maybe have to get different rims???? Thanks!!
JimCost2014 Posted May 23, 2021 Posted May 23, 2021 1 hour ago, Bloody Marty said: These are the original wheels from a 2019 Trail Boss Custom. I know they are 18" but does anyone know the width, backspacing or offset? Anyone know? I'd like to get some bigger tires (35's) after having a leveling kit installed but want to stay with these wheels, I like them. I want just a "little bit" of poke but not too much. Maybe have to get different rims???? Thanks!! Found this, may help. Like the pup, what breed? 2020 Chevrolet Silverado 1500 LT Trail Boss Specs Like the Custom Trail Boss, the LT Trail Boss is equipped for adventure junkies, although it also benefits from the LT’s more luxurious specification. As standard, the 5.3-liter V8 engine is fitted, along with a ten-speed automatic. Mechanical highlights are the raised off-road suspension, the two-speed transfer case, and hill descent control. The exterior has high-gloss black applied to the bumpers, door handles, and grille. 18-inch black-painted wheels are wrapped in Goodyear Wrangler DuraTec tires. Back to 2020 Chevrolet Silverado 1500Chevrolet Silverado 1500 LT Trail Boss For Sale Overview Select configuration: 4WD Crew Cab 147" LT Trail Boss $48,800 Starting Price (MSRP) Engine 5.3L V8 Gas Transmission 10-Speed Automatic Drivetrain Four-Wheel Drive Body Type Truck Seating capacity 6 seater Trunk Volume TBC Fuel Economy City: 16 MPG Hwy: 21 MPG Performance Specs Engine and Transmission Engine 5.3L V8 Gas 6.2L Turbo V8 (+$2,495) Horsepower 355 hp @ 5600 rpm Torque 383 lb-ft @ 4100 rpm Transmission 10-Speed Automatic Drivetrain Four-Wheel Drive Steering Steering Type Electric Rack & Pinion Turning Diameter 46.3 ft Wheels Wheels Type Aluminum Wheels Front Wheel Size 18"" x 8.5"" Rear Wheel Size 18"" x 8.5"" Tires Front Tire LT275/65R18C Rear Tire LT275/65R18C Spare Tire 265/70R17SL Fuel and MPG Fuel Economy Combined 18 MPG City 16 MPG Highway 21 MPG Fuel Tank Fuel Tank Capacity 24 gallons Cruising Range City 384 miles Cruising Range Highway 504 miles Emissions
JimCost2014 Posted May 23, 2021 Posted May 23, 2021 1 hour ago, Bloody Marty said: These are the original wheels from a 2019 Trail Boss Custom. I know they are 18" but does anyone know the width, backspacing or offset? Anyone know? I'd like to get some bigger tires (35's) after having a leveling kit installed but want to stay with these wheels, I like them. I want just a "little bit" of poke but not too much. Maybe have to get different rims???? Thanks!! More info. Chevrolet Silverado 1500 2020 5.3 – Generation: IV [2019 .. 2022] – Power: 355 hp | 265 kW | 360 PS – Engine: V8, Petrol – Options: WT, Custom, Custom Trail Boss, LT Trail Boss, LTZ, High Country, LT, RST – Center Bore: 78.1 mm – PCD: 6x139.7 – Wheel Fasteners: Lug nuts – Thread Size: M14 x 1.5 – Trim Production: [2019 .. 2021] Tire Rim 265/65R18 112T 8.5Jx18 ET26 2.4 275/60R20 115S 9Jx20 ET28 2.4 255/70R17 110S 8Jx17 ET24 2.4 265/70R17 113S 8Jx17 ET24 2.4 LT265/70R17 112Q 6PR 8Jx17 ET24 3.1 LT275/65R18 113Q 6PR 8.5Jx18 ET26 2.8 275/50R22 111T 9Jx22 ET28 2.6
Register a new accountSign in
