I was looking for an alterative to the over priced trailer tpms sensors and found out that they appear to be the same sensors that the 2021 Camaro and Corvette use.  I ran across them on shopchevyparts.  According to the pictures the sensors have the same manufacturer model number ANATEL 015-16-8001, but they are $30 a piece there.  They do not come with the nuts so that is another $3.75 per sensor.  I do not know much about these, so please double check this information if you are going to order some.  I also do not know if there is any programming that is different that would prevent these from working, or if the valve stems are different.  I just noticed the same model number.
Good info.  It makes sense that more than one GM vehicle would use the same sensors.  Too late for me though, I already made the purchase for my trailer.  I hope they work out for others.
Reviving this old thread, is there an aftermarket more cost effective solution to the GM Trailer TPMS #86803857 package for the 2022 Sierra?
I need four and think the $150 per pair is a bit ridiculous.
https://www.ebay.com/itm/134420210986?hash=item1f4c11a52a:g:zg8AAOSwmeJjcYQh&amdata=enc%3AAQAHAAAAoE94HWq%2FBq6Zpbn9dWT3DWQSv1gOSLl93gANV%2Bmtg7slyigREGEEfOpNowgjE5sBt8bfMJz2tF5EX%2BDVDNdUjZS4XV%2F2bngUvtcgk8W87uc5MO1ablhajDYpammxBFFaBirKieDLMCek%2Bv3BmGgVTkQOaYgvfpjL%2Bjl1vppDgjupIEHvhewE6HBOsusXzRxmSb0838HLzFZgDKhwGNJKB%2B4%3D|tkp%3ABk9SR_zDw_K8YQ
They have worked on my 3 2-axle trailers, and on my 3-axle gooseneck.
12 hours ago, Jettech1 said:
This is the system I'm going to buy for our camper.  It's not cheap but gets a ton of good ratings.
https://www.amazon.com/dp/B078TNXBXB/?coliid=I3BXSNE5PMIY0N&colid=1M5R1MGN1XZF7&psc=1&ref_=lv_ov_lig_dp_it
That looks like a great system. I am just trying to use the onboard tools to keep another piece of technology off my dash, and work towards a factory approach.
If you go aftermarket be sure to avoid the Lippert Tire linc setup. Its a complete turd, from the electronics to the hardware. Mine came free with our trailer and its sitting in a box on the shelf because its just junk.
Our Grand Design came with the pre-wired Lippert system.  I did some research and you are right, it is junk.  So the TST 507 that we just bought, I going to replace the repeater system of the lippert system in the pass through with the TST repeater system.  I'm thinking it should be a quick and easy replacement.  And that never goes well for me lol....anyhow that's the plan.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
