this topic was answered, going to new struts
thanks
Edited by RjToole
Get bilstein or eibach TB struts....have plenty of adjustment to get front high as you want....
Could also use an eibach pro truck lift spring to gain another inch and even combine it with TB strut
You dont want another spacer on top of what you have
1 minute ago, Sjordan said:
You want the front significantly higher than the rear of the truck?
Just wanted to get the front another 1.5”-2” higher thank back.
Thank you. I will definitely look into those. I saw some rough country 2” struts that I was thinking about doing with the lower strut spacers but didn’t want to mess the geometry up doing that.
Can the headlights even be adjusted down enough correctly or are you just going to be running around blinding everyone on the road? With the tall front ends on these trucks even when you sit level it looks nose high, this will just compound it. Not sure the reason to buy a truck just to take out some of the usefulness of it... As soon as you put any weight in the bed or hitch the weight is horribly off the front tires taking away steering and braking.
Tyler
Edited by Amcguy1970
  • RjToole changed the title to Leveled front
Tyler
Makes it real easy to prove negligence and win a lawsuit.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
