15 2500 high country. Park assist disabled on dic. Its enabled on the radio. Checked all bumper sensors and they are clicking when in reverse. Pulled fuse disconnected battery for a hr. Still have the message. What am i missing. This just started happening a few weeks ago nothings changed on the truck.
Update, put my friends snap on scanner and showed a u0186 code. Cleared all codes and everything is good. Guess i need a better scan tool
GM did an update on my truck. This problem started. Removed front grille guard, error goes away. Reinstalled guard, problem back.
I betcha they fixed the sensitivity and “blocked “ failures from new
    • *Your
