So I got the truck with the service airbag light on. I did some looking around and no codes are showing up on my scanner, but I don’t believe mine will show the parameters for the Air Bag system. I looked at both the frontal air bag sensors on the bottom of the core support area, and the passenger side one was cracked almost completely ONLY where it screws in at. The actual portion to the front wasn’t broken but both sensors look horrible. Truck came from the North, and so they are corroded as can be. I replaced the passenger side one. Hooked battery back up and it’s still on. I also looked under passenger seat, and drivers seat and the plastic cover that goes over the wiring to conceal them the one on the passenger side was missing, as well as the yellow plug in little plastic rivet that holds it onto the metal plate. So to me it looks like someone has messed with the passenger side wiring under the seat, whether intentional or not, but I guess I’ll have to take it into the dealer to get them to hook it up to the OBD2 port to see if they can erase it. Anyone else ever have this issue? I also noticed my chime doesn’t come on when my seatbelt is off, I’m assuming because my service airbag light is illuminated the entire time.
I have the same truck.  There is a recall about the passenger air bag.  The dealer replaced mine in just a few minutes.  Contact a dealer.  Its free.
As for the truck being from the North, I live in the South too, and I learned about that issue just a few years ago while truck shopping.  Salt is sometimes used in the South too, but no where nearly as much as in the north.  A used car dealer told me he didn't buy anything above the "frost line" or "snow line".....or some such term.  I didn't know what he was talking about so he explained.  I'm 74 and I'd never heard of that issue; corrosion issue from salting the roads. Now I know.  He told me those northern vehicles were more trouble to fool with than it was worth for him as a used car dealer.  Yours may not be that bad; I don't know.  But he said rusting out from under the wheel wells was a big issue.  In the future, you can spend a few dollars on Carfax to get the history of the truck, which will show where it was originally sold.  "Where" is your key for this issue.  In addition, I was truck shopping once and noticed some of the really good looking trucks I was looking at came out of Texas.  I got a little whisper in my ear because a few months prior was when Hurricane Harvey hit Houston and just set there and rained for days and days.  You will probably recall it was all over the news.  So, I ran the trucks I was interested in through Carfax and found they originated in ....you guessed it, Houston.  By the way, glad to see you are a lawman.  Thumbs up!  👍
Edited by Jworks
Yeah I’m from Arkansas, the land of where they never salt the roads unless there’s a 100 wrecks🤣 I’ve checked all fuses, plug ins under the seats, and everything I can think of and even replaced that nasty looking front module. I did notice when I first got the truck that the code c-0899 was on. I’ve read that under current or even an alternator can cause this. Which mine hasn’t been an alternator issue but did have that one code stored. I used my scanner and deleted it but I think I’m going to contact the dealer and tell them about it. I know my speedo is also off by about 5-8 mph. Which is super annoying especially when you’re on the highway and going 5-10 above posted speed and you look down and it makes you think you’re actually going 20 over. I’m not sure if the original owner had larger tires or not because the ones that are on it are stock size, but doesn’t mean they didn’t change them out. I am going to the dealer on Thursday and will mention the airbag issue. I was taking it in for the speedo issue. I thought the needle was sitting a little higher above zero while sitting still but it’s not. I was just going to adjust the needle, but I’ll have them look at it and try to readjust, because even with my scan tool doing live data it’ll show the speed of the speedometer instead of actual speed, so the computer evens thinks it’s going that fast. Yeah I worked in law enforcement for almost 12 years. I am medically retired now, but remember all the storm vehicles because I have my meteorology degree, that the sheriffs dept paid for when they decided to be generous to pay for continuing your education, so I got tasked with working Emergency Management, and also disaster relief and search and rescue for Hurricane Katrina, Moore, Joplin tornadoes, Hurricane Harvey, and several smaller tornadoes. I did the Carfax on it but it showed it was bought from the southern states and shipped up north to a dealer and they never sold it, instead it was labeled as “dealer” vehicle, then the place I got it from had bought it from an auction that the dealership up north had. It’s so aggravating to have these little issues, but it’s not the end of the world. If I could just get the speedo issue fixed I’d be happy with that at the moment. I have a decent sized personal injury settlement coming so paying this off should be easy and I can get these issues fixed and use this as the hunting rig or whatever
Edited by Lawman86
Good deal.  Sounds like the speedo issue should be solvable pretty easy if its a good dealership.  Not all are.  Fortunately I have a really good one nearby.  Some of their prices are reasonable; some are not.  Im having plugs and wires done by a local mechanic for $275.  Dealership I was bragging about quoted $500-600.  So there you go.  Something like you're dealing with I would probably stick with a dealer -- if, its a good one.  It all comes down to how good their mechanics they employ are.  Good luck on your upcoming settlement.
I don’t necessarily have any good shops around me, dealers anyways. I’m an ASE Master Mechanic but when you don’t have a scanner like the ones you had at a dealership it makes it real hard to do what I was used to doing. I was a shop foreman at the time, but I helped a lot when I was bored or wasn’t doing warranty tickets. If I had the extra few grand to get a good OBD2 scanner where I could do most of the calibrations it would be nice. The one I have does some ABS stuff but not airbag stuff or some other important stuff. I’m going to take it down there and have them replace the passenger module because I looked it up by the VIN and it’s never been changed, and that may be what my issue is, plus they can delete the light for me, also I am pretty sure if they’ll put the stock setting on the tires it’ll likely fix it. It’s about + or - 10mph, depending on if the road is flat
This is how annoying it is. I went ahead out of my better judgement and put a VSS in the tail shaft on the trans, and also a passenger airbag sensor, I am having to reschedule my appt for the dealer. I’ve got a sick 3 year old, but I did notice when the truck is in gear and foot on brake the needle is above the 0 mark, not normal cause my last one heck you put it in gear and it stayed below zero as if it was set to give it a mile or two slower before the needle would move. It was so accurate that I had it set like clockwork everyday for all the speed traps. I’m sending a few pics. One is at rest with foot on brake with it in gear, the other one is on the interstate with cruise set at 75 and it shows 85. I got my multimeter and ohmmeter earlier to work on some other stuff. I noticed even though my truck came with the RPO package for electric start they put a aftermarket antenna inside the vehicle but of course didn’t have that key.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
