So after messing about with resetting the HVAC on my truck (https://www.gm-trucks.com/forums/topic/251010-where-is-the-hvacecas-fuse-in-a-2016-silverado/) I've started looking around and have found a leak in the A/C condenser. In fact based on the green substance I found, I'm guessing someone else also found the leak before I bought it a few years back as you can see in the image below it's got a green tint.
All that said, I'm finding a number of complaints from the 2015 Silverado condensers leaking so I'm only assuming my 2016 has the same problematic condenser.
I'd prefer not having to do this job again, so what's a great aftermarket condenser to replace this stock unit?
Thanks to the recommendations here 😉 I went with a Murray A/C condenser. It has a lifetime warranty and certainly looks to be an upgrade over the stock condenser.
I bought one from autozone that had a plate welded down from top to bottom.  Much better design than the stock.
    Daniel422
    Daniel422
  • Who's Online   6 Members, 1 Anonymous, 1,143 Guests (See full list)
