tevo Posted July 16, 2021 Posted July 16, 2021 I want to go to a light truck tire on my 2018 Sierra Denali. I like the wheels on the 2021 GMC AT4. The ford dealer could not tell me if they would fit my truck. They said the only way is to order them and try them. That does not sound right. Dow's anyone know if the 2021 Sierra 1500 wheels are interchangeable with the 2018's? Thank for any comments.
M1ck3y Posted July 16, 2021 Posted July 16, 2021 (edited) I would, "assume" so. Just by looking at them they probably have similar, if not exactly the same offset's. I could use google and compare specs between the two wheels. But so can you! Edited July 16, 2021 by M1ck3y
Hootmay Posted July 16, 2021 Posted July 16, 2021 I have 2021 Z71 wheels and 2021 AT4 wheels that are brand new. I am wanting switch to chrome on both. What do you have?
newdude Posted July 16, 2021 Posted July 16, 2021 (edited) 3 hours ago, tevo said: I want to go to a light truck tire on my 2018 Sierra Denali. I like the wheels on the 2021 GMC AT4. The ford dealer could not tell me if they would fit my truck. They said the only way is to order them and try them. That does not sound right. Dow's anyone know if the 2021 Sierra 1500 wheels are interchangeable with the 2018's? Thank for any comments. Any of the 2021 and prior wheels will fit a 2014-2018. So anything 2007-2021 will fit. The new body 2019-2021 guys can't run older stock wheels without a wheel spacer. You will need new or transfer your tire sensors as the frequency used in a 2021 wheel is different. They are 433mHz, your 2018 most likely is on 315mHz. Edited July 16, 2021 by newdude
Register a new accountSign in
