Hey all, I'm new to this site and a new owner of a 2004 2500HD 6.0/4l80e.  I had a few questions, firstly regarding tire pressure.  My sticker is gone so I can't just look on the driver's side door.  I wanted to know if someone with the same build as mine would be willing to share a pic of theirs.
6.0 lq4 / 4l80e 4x4
Towing package
Crew cab
Thanks for having me
Edited by T0ng5
Forgot to add spec
I have exactly the same truck but mine's an 03 GMC. Sorry about the poor quality cell phone image, but I think it's still readable. I'm running 265/75R16 with 65 psi when the truck is empty. Will run 80 psi when towing or hauling.
More important than what it says on the door, or what anybody else does . . . what does it say on the tires is the maximum pressure?  If it's Load Range E, it probably says 80 psi; if it's Load Range D it probably says 65 psi.  If the tire says less than that, it's probably not the right tire for your truck.
Those are the MAXIMUM cold pressure ratings.  If you are towing or hauling then you probably want to be at or near the maximum.   If driving around otherwise, something less will soften the ride, improve handling, and help wear evenly.
How much less?  Watch for tire wear.  It's like the 3 bears.  If it wears in the middle, then the tire pressure is too high (papa bear, too hard).  If it wears on the 2 outside edges, then the tire pressure is too low (mama bear, too soft).  If it wears evenly, then it's just right (baby bear).  If it wears just on the inside or outside edge, then it's an alignment problem.  Oh, and don't go rotating tires every 5k miles or you won't have a chance to see the wear pattern.  (Revealing my belief that the 5k mile rotation is pushed by tire dealers to cover up problems.)
Thanks guys, I was curious as to what the sticker said.  I've got E rated tires on now, and I'm at 60psi all around.  I'll keep on eye out for odd wear and adjust accordingly
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
