Looking for a set of tows for my lifted Chevy. Chrome of course.
Boost? $456 for the ones I want
https://boostautoparts.com/products/2015-2019-gm-tow-mirrors?variant=43624462087
Trail Ridge? Around $500
Not really liking these
OEM? $850 ouch
https://www.ebay.com/itm/2014-18-Silverado-Sierra-Chrome-Camper-Trailer-Tow-Mirrors-Door-Harnesses-OEM-/262652505671?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&mkrid=711-127632-2357-0
Nice but not $850 nice.
Not afraid to drop the $850 though if you give me a good reason.
Anyone ever need to reprogram BCM?
I'm leaning towards the Boost but I want to hear what you got and why you got/like them.
Thanks Guys.
Edited by dieselfan1
Not sure if I believe this either.
I heard they are months behind. (Boost)
Hi, Jim, I had the stock Chevy tow mirrors installed at the dealer. The door harness had to be replaced in order for them to function properly. Also, pretty sure they had to program the BCM.
I also ordered @pgamboa's harness for turn signal function on the marker lights.
Later, I also added the cameras to the mirrors for rear visibility when changing lanes.
https://accessories.chevrolet.com/product/extended-view-tow-mirrors-in-chrome-23372181?vin=3GCPCRECXHG303310&categoryId=98023
Edited by MikeBMW
Went with the Boost mirrors. Ordered 7-27 shipped out today 8-3. No Corona B.S. delay.
You're still gonna need a harness to make it work properly.
For me, I always stick with stock, other than some @pgamboaharness mods.
And, AutoSync, BtDiesel, level, shocks  ... umm, never mind.
Let us know how the install goes and, please, keep us updated! :)
Edited by MikeBMW
OEM? $850 ouch
Thanks Guys.
Okay, how bout you drop $850 in an envelop with my address on it. I'm sure you still have it; and donate to Peppers upcoming 150K services 😉
C'mon man, that's funny, right?  :)
  • Haha 1
I ordered the harness set they recommended.
No other wiring required. These are basic manual fold, no forward spot, no sequential blinker. Just a reverse/cargo light
Are there issues with visibility when changing lanes that we would need cameras? I have thought about adding tow mirrors, even though I dont really tow right now. Figured it would add visibility. I dont think the stock ones cover enough.
I can't find any cams for stock mirrors, though I have seen them,, and, as mentioned previously, even the setup I have doesn't seem available at the moment.
Indeed, the side view cams offer a lot of visibility, even for turning corners to keep away from curbs, as well as any cars in the blind spot when changing lanes - though the tow mirrors are pretty good with that, as well.
Would you say the tow mirrors are worth it for better visibility over stock even though not currently towing? How is the vibration I have read about etc?
No vibration on mine, but they are the stock Chevy mirrors as installed on a 2500.
They are definitely better for rear and low side ward visibility over stock, but they do add a bit of a right and left side front sight challenge but it's not too hard to adjust once using them for a bit.
To answer your question, yes, for me, worth it. I've switched to using the side mirror cams all of the time, not just on the highway.
Edited by MikeBMW
I have indeed thought about it. I would have the ones off the accessory site installed. The lower side especially backing up is what I would like to increase. I have never understood making big vehicles then putting small mirrors on.
Yeah I think I have read from a few posts, It runs around $1200 for the mirrors themselves and then install.
  • 4 weeks later...
Byrds
The visibility in the mirrors is a huge improvement.
The size of the mirrors do block visibility similar to the A pillar.
My Boost mirrors have no vibration.
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 642 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
