Hi.
I plan to change the gear ratio on my Chevrolet Express 3500 2011 from 3.42 to 3.73 to haul my trailer. Does the stabilitrak and abs will still work, or will it need a new programming?
Thanks.
At the very least you'll need a handheld tuner to make the correct changes to the ECU.
I have a Hypertech Power Programmer III for my Silverado that has this option. If you don't do this, the cluster will light up like a Christmas tree, and the transmission will slam shifts, all at the incorrect time. A total cluster****.
I went from 3.23 to 4.10.  Only issue was speedometer and odometer.  This was 11 years ago on my 2010.  Jason at Blackbear fixed my speedo via the tune.  Drove it for a couple of months before the tune and had zero issues with drivability.
Interesting. I inputted the incorrect gear ratio in that Hypertech programmer, and my truck wigged out big time. It must change a bunch of stuff in addition to the speedo/odo calibration. I only went 2 miles, and I thought my driveline was going to snap! Friggin thing was shifting at the wrong time, and literally every single light in the cluster was on.
Never know how these friggin computers will react. They belong in a desktop or laptop - NOT in automobiles! 😉
Edited by Jsdirt
  • Thanks 1
They get to cute with them. Kids that can't keep their mitts out of the cookie jar.
  • Haha 1
2011 Avalanche
I went from 3:08 to 4:10. Huge Improvement in drive ability and towing. I changed the speedo with Hyper tech and was ok but trans shifting was off and soft. I tuned with Black Bear and now is great. Shifts great and much more power Now I drive in D instead of manually holding in gears to stop the constant shifting up and down. Tow  mode better too. I tow a 7000 trailer and in 5th at 60 is about 2200 RPM.
I would definitely change the gears and tune again.
2200 RPM at 70 in 6th with 17 inch tires
Also installed Derale trans cooler with fan cause the trans runs hot in these even with no load in the mountains etc. Put it between the grill and radiator tight fit but works good.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
