Recently my 2019 Silverado inside temp will display -40° and my ac will quit blowing cold air. This usually happens after it rains or hitting a puddle of water. I can pull the positive battery cable off for a few minutes and it starts working again. Any suggestions on what this could be? Thanks
Loose connector at the sensor behind the grill?
Often, temp circuits will display -40 as a way to indicate there is a circuit/sensor fault.
I had my passenger side mirror replaced. The AC stopped working after install. Drove back to dealer. Dealer said there is a sensor in mirror that they failed to hook up. They fixed it promptly. I would look there.
