I can get a nice set of 22" rims that I want to put on my stock height 02 Sierra 1500 4wd. Tires are 305/40/22 that are on 22s and I currently run 285/75/16s. Would these bolt right on without rubbing it do I need to put a lift on my truck first???
Use a tire size calculator, simple as that. The 22's are a smaller tire but wider than what you have. They will fit but might rub on full lock turns.
The 22's will be equal is size to a factory 265/75/16 but much wider. Also they will be much heavier.
I did use the calculator but others say they have and haven't had issues with rubbing at any type of degree of turn. So I was curious if anyone has mounted that size in the stock ride size on the forum because y'all are amazing.
